Mark
Glad you are sorted but don't give up on the 'junk" welded up chuck and arbor just yet.
I'd set up a true running, turned in situ if need be, stub a bit longer than the chuck is deep and close to its maximum acceptance size in the lathe. Grab it with the chuck and have at the weld with a HSS tool ground to a shape similar to D or E carbide inserts. Basically a diamond. Blunter, larger tip angle, within reason is better. That way you can get at the weld area with minimal cutting of the chuck and arbor. Weld will almost certainly be softer. Be a bit generous with your cut depth so as to be sure that chuck and arbor will separate once removed from the lathe.
Although the weld suggests that either the female taper in the chuck or the male on the arbor is damaged in some serious way I think it more likely that previous operator was inexperience, stupid or both. Frankly if you just loose a 1/16 inch or so of mating taper length it matters not al all.
If they are actually damaged cleaning either or both up is a nice exercise in precision setting up and careful machining. I've done 5 or 6, maybe more, over the years with every success so how hard can it be? Bit of thought, patience and not getting rush-headed about things gets the job done.
If the male taper really is seriously affected just lay on a decent layer of weld with an ordinary stick welder and start over. She'll be fine. That sort of approach is almost essential if you need to fit a chuck to a Fobco 7/8 which are notorious for having a longer than usual taper in the spindle so common chuck – MT arbor pairs don't reach in far enough to fit. It is within specified gauge lengths but normal practice is to make things shorter! easy show off job.
Clive.
Edited By Clive Foster on 31/01/2018 19:54:04
