Corbett XL Shaper
Corbett XL Shaper
Home Forums Beginners questions Corbett XL Shaper
Viewing 15 posts - 26 through 40 (of 40 total)
  • #182303
    thaiguzzi
      @thaiguzzi
      And i do all of my graduations of dials etc on my 8" Boxford shaper, with my H/V Vertex 6" rotary table and dividing plates. Release belt tension, set the stroke, and manually rotate the handle. Good fun and easier than on a lathe with a lining tool.
      IanT
        @iant
        Hi Thaiguzzi
        I was intending to use my Adept hand shaper (with some form of stop) to engrave a dial I need to make but your idea sounds a much better approach.
        I hadn't thought of using my powered Atlas in "Manual Mode" for this – simply using the stoke setting for line depth. Simple idea but sounds very workable. Brilliant – I like it !!!
        IanT
        #182343
        thaiguzzi
          @thaiguzzi
          No probs. Works very very well. Do all the tens in one setting, then the fives, and finish off with the ones.
          Just recently done a large shaper excercise. Full stroke used and practising machining all the vees (like dovetail cutting) and large t slot. Could have saved a few hours doing some ops on the Senior M1 with vertical head, but i was determined to do EVERY op on the shaper, bar drilling and tapping holes, and sawing off each piece in the Denbigh power hacksaw. Started off with two flame cut billets of steel, ended up with 11 Dickson/Bison style QC tool holders, 9 std, 2 part off blade holders for my Boxford VSL. 76 hours from start to finish inc drilling, tapping, sawing and hot oil blackening. About 3-4 hours per day on the job.
          #182344
          thaiguzzi
            @thaiguzzi
            Sorry, that time also included turning the 12 (one spare) knurled height adjusters.
            #182365
            Colin Heseltine
              @colinheseltine48622
              Ady,
              Thanks for posting that review from ME. Its nice to see the Corbetts gets good write up. I just need to sort out some tooling for mine.
              Colin
              #182367
              IanT
                @iant
                I was looking for something else entirely this afternoon and spotted an advert for your Corbett XL shaper Martin (ME 2742 – December 10th 1953).
                Back then it would have cost you new – £57-10-00 (or just £52 without the motor!). Not sure what that would be in todays money – quite a bit I would think. A 4.75" Rotary Table was an extra £6-10-0.
                A new Boxford Model CSB was being advertised at £95-17-6d…which also sounds quite reasonable.
                smiley
                IanT.
                #182442
                OuBallie
                  @ouballie
                  Thaiguzzi,
                  Re. Dickson tool holders.
                  I need to make some as well, using my Boxford, but have never tried cutting vees, so would appreciate any details of the tooling you used, plus hints please.
                  Geoff – The price of S/T2 Dickson tool holders makes my eyes water.
                  #182506
                  thaiguzzi
                    @thaiguzzi
                    Hi Geoff,
                    # Send me a pm with your email adress and i will send you a bunch of photos which will be better than a 1000 words.
                    # As all the Vees are "external" so to speak, tool angles and types are not critical, although i did use my "internal" tools which will always have a smaller included angle than the Vee itself. Generally 3 degrees less each side. The whole top slide/tool slide needs to be set over for the correct angle. Do not rely on the Boxford graduations as mine were a good 1/2 degree out. i used one of those £20 odd quid Chinese copies of the multi facet Russian engineers protractor. Clapper box also needs to be set correctly to stop dragging on the return stroke.
                    # The T slot was done using a 90 degree bent grooving/parting type butt welded HSS tool brought from Cromwells, modified shank to suit the toolpost, and sharpened on my Stent to the full correct width, cutting the T of the slot in one go.
                    # I have a 17" table extension for my shaper which enables me to use my Vertex H/V 6" Rotab AND tailstock for longer items. In this case it was used to hold my BIG H/D rack vice which comfortably held the 7.5" long billets of steel. The toolholder's details were machined so i could do all machining ops on 5 tool holders in one setting, and then saw off to suit.
                    # Without the table extension and rack vice, you will have problems doing them this way, the std vice is too small, and the table not big enough to clamp a suitable large chunk of steel, you may end up making maybe a max of 2-3 at a time.
                    # My toolholders are the T.0 or T.1 type, i forget, but they take a 5/8" tool in the shank and are 73mm long. Correct for the Boxford lathes.
                    # Highly recommend making a purpose built parting off holder at the same time a la original Bison/Dickson.
                    # Lots of good info on the NEMES American site for shapers, tooling etc.
                    # Hope this is of use, another ole Norfolk Boy.
                    Mike.
                    #182556
                    OuBallie
                      @ouballie
                      Mike,
                      PM sent.
                      Thanks.
                      Geoff – Trying to get my head round iMovie and its workings.
                      #182576
                      Martin King 2
                        @martinking2
                        Hi Mike, PM sent
                        Martin
                        #182602
                        thaiguzzi
                          @thaiguzzi
                          Hi guys,
                          just sent 13 emails with 5 pics each to the pair of you.
                          Mike.
                          #182605
                          Martin King 2
                            @martinking2
                            Hi Mike, Many thanks for the great pics and info, much appreciated.
                            Martin
                            #182648
                            OuBallie
                              @ouballie
                              Thanks Mike,
                              Your pics make it look easy, so I'm now searching for 1.3/4×1.3/8" or closest steel bar.
                              A plea to the forum please for suppliers who do not want my arm and leg in exchange.
                              Given up on trying to make sense of iMovie 11 and its workings for now, so the YouTube video of me taking the BH600G Apron off is on hold right now.
                              Geoff – Life's just too short, and my treatment isn't helping
                              #182691
                              thaiguzzi
                                @thaiguzzi
                                No problems guys,
                                glad you appreciated my time on the computer (*#*#ing things!).
                                All the best,
                                Mike.
                                #183157
                                thaiguzzi
                                  @thaiguzzi
                                  Colin, you have a pm.
