connecting rods
connecting rods
Home › Forums › Beginners questions › connecting rods
  • #124085
    david simmo
      @davidsimmo
      hi on a 4-6-2 the connecting rods ? how much movement on the joint between the rear couple rod and drive rod thanks dave
      #6779
      david simmo
        @davidsimmo
        rods
        #124108
        MICHAEL WILLIAMS
          @michaelwilliams41215
          Hi Dave ,
          I don't quite understand the problem .
          Could you please explain a little more what you need to know ??
          MikeW
          #124114
          david simmo
            @davidsimmo
            hi mikew it the up and down movement before the rods are fitted ( the trailing rod movement at the linkage thanks dave
            #124137
            michael howarth 1
              @michaelhowarth1
              Dave ….I would have thought that if the centre joint was made in the standard way with a tab on the rear coupling rod fitting into a fork on the front coupling rod then this would automatically allow for plenty of up and down movement. The limits of the up and down movement is dictated by the hornblocks and springs so should be quite easy to measure. Of course there should not be any lateral movement at this joint.
              Mick
