Conjunction of Moon and Jupiter
Home › Forums › General Questions › Conjunction of Moon and Jupiter
Viewing 25 posts - 1 through 25 (of 31 total)
  • #22474
    Sub Mandrel
      @submandrel
      #112497
      Sub Mandrel
        @submandrel
        Clear skies tonight so anyone who wishes they'd seen the earth-grazing asteroid a few days ago you can make up for it by seeing the Moon and Jupiter very close together.
        Unfortunately when I have zoom so both are in the viewfinder my camera won't focus properly, but I have a pics of both of them from about 20 minutes ago.
        This isn't really off-topic as optics and photography have often featured in the pages of ME, and my question would be – any suggestions for getting digital cameras to work with telescopes?
        Moon
        #112499
        V8Eng
          @v8eng
          I think it's called "digiscoping" try a search for it.
          I thought about it for ocasional bird watching some time ago, but could not work out if my camera was suitable, so did not take it any further.
          Edited By V8Eng on 18/02/2013 21:18:25
          #112504
          Sub Mandrel
            @submandrel
            My camera was reluctant to work with the scope (itself a 30mm lens with an eypiece converter on it). I've had feeble results with binoculars and my compact digital.
            I've heard of mounts that unite camera and scope – such a thing should be easy enough to make, if I knew how they work!
            With the 'scope' I could see three of jupiter's moons just now.
            Phil P
              @philp
              Thanks for the heads up.
              I have just had a great half hour outside in the freezing cold with our telescope.
              It must be one of the clearest nights we have had for months.
              Phil
              #112511
              Hi Speed Scrap
                @hispeedscrap
                I noticed that great sight here (Melbourne, Oz) too, amazing.
                But your moon is upside down!!
                Dave.
                #112513
                V8Eng
                  @v8eng
                  T
                  Edited By V8Eng on 18/02/2013 22:39:28
                  #112515
                  John Stevenson 1
                    @johnstevenson1
                    Posted by Hi Speed Scrap on 18/02/2013 21:59:51:
                    Dave.
                    Obviously not fit for purpose ?
                    #112524
                    Gone Away
                      @goneaway
                      Posted by Stub Mandrel on 18/02/2013 20:53:50:
                      …… anyone who wishes they'd seen the earth-grazing asteroid a few days ago
                      See it here if you want.
                      #112536
                      V8Eng
                        @v8eng
                        Apologies for my last posting , I was part way through editing it and got called away.
                        Anyone looking to couple cameras and telescopes might find these useful.
                        http://www.srb-griturn.com/index.asp
                        http://www.digiscoping.co.uk/?Cat=Home
                        An Internet search engine will reveal lots of other dealer sites, and useful information on the subject.
                        Edited By V8Eng on 19/02/2013 10:09:04
                        #112569
                        Ed Duffner
                          @edduffner79357
                          Hi Neil,
                          The adaptor you mentioned is a T-Ring or T-Adaptor and depends on the type of camera you have e.g. DSLR or Compact. I use a T-Ring with my DSLR for astrophotography and these connect the camera body directly to the telescope focusing tube (on an SCT scope) without the need for a camera lens.
                          The DSLR adaptors have a thread on one end to attach to a scope and the other is machined or threaded to fit to the camera's lens mount. This setup basically makes the scope a long focal length lens.
                          The compact camera adaptors are usually just a sleeve that threads onto a scope and allows the smaller diameter (non-detachable) compact lens to slide into the tube and is secured with some kind of locking screw or clamp, or just held in place with the camera mounted on a bracket of some form. I've not used this method but I'm sure there wil be many articles on line to show the setup and different ways to achieve focus.
                          Digiscoping is a term more used for birding or wildlife study.
                          I'm hoping to make an equatorial mount when I can get hold of a lathe and have a better understanding of machining and gears etc. The "seeing" here in Bristol was a little misty but I did notice the two objects last night.
                          Ed.
                          #112574
                          David Littlewood
                            @davidlittlewood51847
                            Sid,
                            Many thanks for posting that link: as I imagine many others did, I went out with my binoculars several times on Friday night, only to see an unrelieved bank of dense cloud every time. I don't imagine, even if it had been clear, that I would have had as good a view of it as the one in that recording.
                            David
                            #112576
                            Gone Away
                              @goneaway
                              David,
                              Lot's of good stuff on the APOD site. One of the first places I visit each morning.
                              #112617
                              Sub Mandrel
                                @submandrel
                                Thanks all.
                                V8 some useful ideas on those sites – interesting taht t-mount is still used for DSLRs – I have a 300mm standard and a 500mm mirror lens with t-mount, so presumably just an adaptor would give me som impressive lenses.
                                The two pics above were taken on my Nikon bridge camera with 4X digital zoom – effectively 2400mm so about 48x. Apparently Gillieo made do with 20x so I takes me 'at off to 'im, I does!
                                Sub Mandrel
                                  @submandrel
                                  Yesterday morning the sun was very weak through the thin cloud not long after sunrise. I got this pic with the camera set at 80ASA, leaning on a car roof:
                                  Very pleased with the sunspots – never caught those before. They match up with the live picture on NASA's SOHO site, but for some reason they have a slightly sharper picture than mine!
                                  Russell Eberhardt
                                    @russelleberhardt48058
                                    Nice one Neil. I've never dared point my camera at the sun like that for fear of burning out the ccd sensor. Here's the moon taken a couple of years ago when I was playing with my new bridge camera:
                                    Russell.
                                    Edited By Russell Eberhardt on 11/04/2013 15:54:44
                                    #116656
                                    Sub Mandrel
                                      @submandrel
                                      Nice balance with the sky, Russell. I would not are zoom in on the sun, but it was so weak you could look directly at it.
                                      Robert Dodds
                                        @robertdodds43397
                                        For you moon watchers out there I was sent this link to a full moon over Wellington NZ.
                                        I was impressed by it anyway.
                                        Bob D
                                        #116686
                                        RICHARD GREEN 2
                                          @richardgreen2
                                          KLAATU BARADA NIKTO
                                          Edited By RICHARD GREEN 2 on 12/04/2013 09:29:48
                                          #116690
                                          mark mc
                                            @markmc72333
                                            I used to try my hand at astrophotography a few years back before children etc. still have my telescope and camera stuff safely tucked away, but here's a few shots i was quite happy with.2006,10.0220 m31.jpg
                                            img_13_rgb_sort.jpgEdited By mark mc on 12/04/2013 10:06:44
                                            Edited By mark mc on 12/04/2013 10:08:05
                                            Edited By mark mc on 12/04/2013 10:09:01
                                            #116696
                                            Joseph Ramon
                                              @josephramon28170
                                              All looks a bit nebulous to me
                                              very impressive, Exactly what equipment do you have? A star-tracking equitorial mount would be a good project.
                                              Joey
                                              #116706
                                              RICHARD GREEN 2
                                                @richardgreen2
                                                IT'S LIFE JIM,…….. BUT NOT AS WE KNOW IT………………
                                                #116730
                                                mark mc
                                                  @markmc72333
                                                  Not got the must fancy stuff but it works not to bad . The scope is a skywatcher 8inch reflector mounted on a heq5 tracking mount, the camera is a cannon 350d mounted to the scope on a t-ring. Abit hard to focus as can be seen but works ok. those shots were really 10-15 long exposures all stacked one on top of the other.
                                                  #116765
                                                  Ian S C
                                                    @iansc
                                                    If you go back in the Model Engineer there are articals on making telescopes ie., 1941 W.E. Moorhouse Constructing a reflecting telescope, or 1912 Grinding Mirrors, so telescopes have been with ME for over 100 years. Ian S C
                                                    #116769
                                                    Sub Mandrel
                                                      @submandrel
                                                      I know someone who went to night school and ground up their own mirror, many years ago. He found the whole process so soul destroying that he never had it seilvered, let alone built a frame for it. He has an off the shelf digitally controlled scope, but feels that being able to 'dial in' a position is fantastic in some ways, but takes half the fun out of it!
