Hi Coggy,
I have been in exactly the same position as you regarding a lathe just recently. I had pretty much decided on a Warco 280/290 and a DRO.
As I’m really just a beginner, I thought, get the biggest lathe I could afford. In the end, with the discount ARC have at the moment, I ended up buying a SC4 from them. Yes, it’s not got a threading dial, it’s only got a 20mm hole through the spindle and the power cross feed is a bit naff(it’s too easy on disconnecting the cross feed to engage the fine saddle feed and vice versa) but it’s nearly half the price of the 280 and with a fixed steady, the small spindle hole isn’t an issue – well to me it isn’t. I have got into the habit of winding off the top slide before disengaging the cross slide.
All metal change gears and it comes with the 127 gear, so both metric and imperial screwcutting. I have now cut M14 fine, M12 fine, M10 both coarse and fine and I’ve got 3/8 BSF and a left hand 1/2 BSF coming up shortly – hopefully they will go as well as the metric have.
I learnt when I bought my mill that the machine itself is only half of the cost. The other half is all of the tooling. My decision was really made on the fact that being from the ‘flat part of Lincolnshire’ ARC are not too far away in Leicester and they are a friendly bunch – whenever I’ve been there, the kettle has been on😂 (The other reason is that I’ve been to 2 shows and both times been on the Warco stand and been unimpressed as a potential customer – the first time nobody spoke to me, even though I was on the stand for about 10 minutes, the second, they seemed uninterested. Add to that, no stock. I was willing to wait for stock, but in the meantime, I made the decision)
I have made sure that all of the tooling I have bought is the biggest the SC4 will take, so if I’m future I decide to upgrade, hopefully I don’t have to buy another load of tooling.
One of the first things I did with it, was to screwcut a M14x1.75 thread and apart from my stupid mistake not setting the top slide correctly, the lack of thread dial, to me, is a non issue, just keep the half nut engaged and run forward and back.
As to a DRO, I bought a DRO with my mill but my budget wouldn’t run to one when I bought the lathe. Add to that, I had seen the LCD displays at the Midlands show. I had pretty much decided that was one of the first things to buy when funds ran to it. I have ended up buying more tooling with that budget. I think it’s going to be one of those ‘nice to have if I’ve got some spare cash in the future’ things.
I have no connection to ARC other than a satisfied customer
Cheers
Mark
