Cleaning up steel after silver soldering
Home › Forums › Beginners questions › Cleaning up steel after silver soldering
  • #346476
    Peter Simpson 1
      @petersimpson1
      I have fabricated the cross stays for my 5" gauge BR Standard Class 2 loco. Having silver soldered one of them, what is the best method to clean the steel up prior to priming them ? Is there any way of pickling them ?
      #9139
      Peter Simpson 1
        @petersimpson1
        #346484
        Roderick Jenkins
          @roderickjenkins93242
          Following advice from JasonB, I've just pickled a steel fabrication in neat brick cleaner. Worked very well, it removed the flux residue and black oxide.
          Rod
          #346485
          Tim Stevens
            @timstevens64731
            The most often recommended solution for this is Citric Acid – which you buy as a powder and dissolve in water. It is relatively harmless to life, so not nasty to use. A search on the web will find supplies, and advice about concentrations, temperature, etc.
            Hope this is a start to an answer – Tim
            #346492
              Citric if you have all weekend to make one part, Brick Cleaner if you want to get on with the job as it only needs about 1/2hr in the acid and is also far more effective at removing Tenacity and HT5 flux than the citric.
