Citenco Motor
Citenco Motor
Home › Forums › General Questions › Citenco Motor
  • #22962
      How to dismantle ? …
      #136083
        I have a Citenco Varicontrol motor that needs some refurbishment.
        It's the type that was commonly used as a Laboratory Stirrer.
        24:1 worm reduction on the output; and two concentric knobs on the back end, giving on/off and continuous speed control.
        I have removed the bell-housing from the output end, but cannot access the other end, because the speed control knob is stubbornly fixed. It's held by two radial grubscrews … but I suspect that these are very long. I have tried various penetrating fluids, to no avail. The knob is a couple of inches diameter, and the threads are presumably in the central boss.
        Before I resort to destroying the knob, just to remove it … Does anyone have one of these motors? A photo, or description, of the underside of the knob would be a great help. …
        If I know the topography, I may be able to inject some penetrating fluid into the right places.
        Thanks
        Edited By Michael Gilligan on 21/11/2013 09:15:02
        #136103
        Swarf, Mostly!
          @swarfmostly
          Hi there, Michael,
          I have a motor that I think is of the type you mention.
          However, I'm currently confined to barracks with a lurgi so I can't get to the workshop.
          If you haven't heard from me in a week, send me a PM to jog my memory.
          Best regards,
          Swarf, Mostly!
          #136109
            Swarf …
            Many thanks for this.
            I wish you a speedy recovery.
            Cornish Jack
              @cornishjack
              Hi Michael
              I have one of these motors … and I have located it!!!!!surprise
              Can take photo's, if still needed.
              Rgds
              Bill
              #136318
                Thanks, Bill
                Swarf, Mostly! has kindly put some pictures in an album … but his is a slightly different model [probably earlier, and better made]
                Mine is the "Blue Hammerite painted" one, Model KTQS II
                The knob has a stick-on Aluminium label, but I suspect it looks much like Swarf's on the underside.
                My guess is that the nice Brass insert was "improved" to a Steel one, to save a few Farthings.
                … The screws are "impossibly tight", so probably rusted-in.
                If yours is the same as Swarf's then there is no need for photos, but if it's the one like mine then a photo of the underside of the knob would be much appreciated.
                Cornish Jack
                  @cornishjack
                  Hi Michael
                  This one is KQPS34 looks similar to Swarf's but badged for Griffin and George. Speed control knob is secured by a pair of grub screws, so all 'same-same' by the look of it.
                  Rgds
                  Bill
                  #136326
                  Cornish Jack
                    @cornishjack
                    Hi Michael
                    Rgds
                    Bill
                    PS see your PMs
                    #136328
                      Thanks Bill,
                      I think mine will be bathing in PlusGas tomorrow.
