Posted by Nick Clarke 3 on 10/03/2021 09:56:28:
Posted by Pete. on 09/03/2021 16:36:18:
Nick, unless I missed something, which is quite possible, the new versions of the x1 and x2 both have 400mm tables, so I can't understand how one would take up more space than the other?
'The depth front to back and height of column are slightly more on the SX2 and these were the dealbreaker. The space I had for it meant that the wide table was less of an issue, and part of the reason I went for the Sieg version from Arc and not the Clarke CMD10 (that and price!)
You must be extremely tight for space, I never really gave much thought to the height or depth, as they're both quite small It's hard to picture a workbench that couldn't take those 2 dimensions, I did have one of the yellow Clarke x2's.
I was just trying to dissuade Nick from buying a smaller machine for the same reason I tried to dissuade him from buying that vertical slide for the lathe, a complete beginner is trying to understand the basics, and top trying to deal with clamping arrangements on a tiny vertical slide can be frustrating for the experienced, enough to put off a beginner from continuing.
A slightly larger machine is a bit more forgiving in novice hands, where as you know how to make it work to get around its limitations, I just didn't want him to end in the same situation, buying something that puts him off continuing.
