‘Chinese finger-trap’ in steel wire?
Home Forums Workshop Tools and Tooling ‘Chinese finger-trap’ in steel wire?
  • #18311
    Tim Stevens
      @timstevens64731
      Is there a better name?
      Tim Stevens
        @timstevens64731
        In olden times, mechanics used a tube of steel mesh to pull oil-seals into place, and I need one now to pull wiring through sleeving etc. So, do they still exist as a tool, and what are they called? I can't see the old name being popular in these 'enlightened' times.
        I have found surgical devices of this type on ebay, but at silly prices plus silly postage, but I don't need that degree of sterility etc.
        Hoping someone can put me on the right track
        Regards, Tim
        #271243
        Les Jones 1
          @lesjones1
          Would the woven screening layer of screened cable or coax do what you want. It is copper rather than steel but it may be strong enough.
          Les.
          #271244
          Nick Hulme
            @nickhulme30114
            Posted by Tim Stevens on 11/12/2016 18:03:55:
            There is nothing in the least bit offensive about it at all, it refers to where it was invented.
            The times you refer to are dark, not enlightened!
            #271247
            Mike Clarke
              @mikeclarke87958
              Hi,
              I have used cable grips (Chinese fingers) for a product I developed at work:
              http://www.cablegrip.co.uk/stype.php
              Not sure if they will sell one offs (or if it's what you're after!) – but you can try.
              Cheers,
              #271249
                You can buy them as extras for the fibreglass cable rods see bottom of page here
                #271250
                Frances IoM
                  @francesiom58905
                  I bought mine from any good hardware/wholesale electrical shop – there is a threaded rod with screw-in ends such as hooks, magnets etc used by sparkies to wire buildings – one fitting is the wire mesh you describe – maybe not small enough for you but I pulled CAT5 cable through holes and conduit with it
                  Edited By Frances IoM on 11/12/2016 18:31:45
                  #271252
                    It says nothing about enlightenment, but Wikipedia seems comfortable with the name.
                    https://en.m.wikipedia.org/wiki/Chinese_finger_trap
                    Tim Stevens
                      @timstevens64731
                      Thanks, everyone – just what I needed. And now I have been reminded of the principle, I can have a go at weaving my own …
                      What are you making, dear?
                      Oh, just a thing for pulling wiring through holes. It should save me about 13 quid.
                      Really, dear? And you only been at it for three days, so far …
                      Tim
                      #271256
                      Speedy Builder5
                        @speedybuilder5
                        Or our favourite site –
                        BobH
                        #271257
                        Mike E.
                          @mikee-85511
                          Not sure what they are called here in the UK, but overseas we they are known as "Basket Grips". Try googling Greenlee electrical products.
                          #271258
                          Mike Clarke
                            @mikeclarke87958
                            Posted by Mike E. on 11/12/2016 18:48:56:
                            CABLE GRIPS
                            #271265
                            Colin Heseltine
                              @colinheseltine48622
                              I have a number of these in different sizes for pulling cables, predominantly Cat5 cable. I've always known them as cable socks. The ones I use are from Super-Rod. They call theirs Super-Grip. There are a range of three sizes depending on size of cable you wish to pull.
                              Colin
                              #271268
                              Bazyle
                                @bazyle
                                I note one of the suppliers comments "more reliable than insulating tape" which for an few off jobs seems to be the cheaper answer.
                                #271269
                                Colin Heseltine
                                  It may be cheaper in some ways. When you are pulling cables along a purling 15 to 18 metres in the air using 10 to 15 metres of cable rods, its a bit of a b….r when the insulating tape separates at a join in the purling and its just taken 20 minutes to get the cherry picker into position to pull the rods and cable over a high bay aisle in a warehouse. This is why I now only use the cable socks.
                                  Colin
                                  #271271
                                  John Reese
                                    @johnreese12848
                                    #271273
                                    pgk pgk
                                      @pgkpgk17461
                                      Similarly used for surgical tube attachments..chest drains in particular in my patients. Assuming you only have one light to medium duty pull to do then appropriate fishing line is a quick answer.
                                      Howard Lewis
                                        @howardlewis46836
                                        Don;t Screwfix, or Toolstation sell something like this for drawing cable through conduit?
                                        Or maybe too large for your job?
                                        If it is not too long, I have made do with a length of small diameter piano wire, with a small hook formed in the end
                                        #271306
                                        Roger Head
                                          @rogerhead16992
                                          yes
                                          Interesting video in that link, pck_pck. Just the thing for your average home-study courses in open-heart surgery etc.
                                          Roger
                                          #271317
                                          john fletcher 1
                                            @johnfletcher1
                                            We called them drawing in socks, put it over a steel wire armour cable to enable us to draw a cable through ducts. For conduit we used a steel drawing in tape, we shaped a piece of conduit circular to keep it in, now there is plastic version. Aldi had some slender fibre glass rods which screwed together with various end pieces which are very useful when passing cable in lofts and under floor boards, I made some extra magnetic end pieces for mine,much better than galvanised steel wire. The fibre glass rods are available from electrical wholesalers John
