Posted by JasonB on 01/06/2017 13:38:36:
Michael, any chance of a photo of the welds, I had always thought these sets were not upto welding well not unless you include lead burning in that. Cup don't seem to say it can be used for welding?
Sorry i'm using weld out of context, I've actually hard soldered, I can show pics of that but not true welding I suppose.
I needed to fix a lampshade where the ring had come off it, so I cut out a mild steel ring with square two lugs, which I rolled each of into a tube shape with some pliers, little gap left at the top for solder and around the sides, fits beautifully now.
My propane burner flame would've been too hot (over a large area, because the nozzles are chunky) and burnt the material, which I covered to protect it. The little flame was perfect for it and very hot.
I have used it to cut through (gas axe) 3mm mild steel, you need goggles for that though and it works. So I presume it could weld?
Could even put up a video if I knew how and show you it cutting through a piece of scrap!
Michael W
Edited By Michael-w on 01/06/2017 14:22:02
