Cheap chinese Involute gear cutters
Home Forums General Questions Cheap chinese Involute gear cutters
  • #369562
    Matt Homer 1
      @matthomer1
      What does the Module signify in these gear cutters. I understand the DP and pressure angles but they all seem to specify various module numbers ?
      Thanks
      Matt
      Specification:
      • Brand new
      • Module: M1
      • Material: HSS
      • Bore: approx. 22mm
      • Color: as picture shows
      • Pressure Angle: 20 degree
      • Quantity: 8pcs per set
      Each of Gear is different:
      • 1#: 12-13 Gear
      • 2#: 14-16 Gear
      • 3#: 17-20 Gear
      • 4#: 21-25 Gear
      • 5#: 26-34 Gear
      • 6#: 34-54 Gear
      • 7#: 55-134 Gear
      • 8#: ≥135 Gear
      Matt Homer 1
        @matthomer1
        #369568
          Module is the metric system of measuring gears, DP is the old imperial way.
          MOD 1 is equivalent to 25.4DP
          Edited By JasonB on 29/08/2018 15:02:18
          #369569
          Anonymous
            Module is the "metric" way of specifing the size of gears. In simplified terms it's the inverse of DP. The precise definition is that the module is the length of the circular pitch in millimetres, so the bigger the number the larger the gear teeth.
            Confusingly the numbering of module gear cutters is the reverse of DP cutters. So a #8 DP cutter is for the same number of teeth as a #1 module cutter, and so on.
            #369570
            Thor 🇳🇴
              @thor
              Hi Matt,
              The Module system is used for metric gears, see here. Diametral Pitch = 25.4/Module, more formulas for metric gears here.
              Thor
              #369571
              Matt Homer 1
                @matthomer1
                Thanks Guys…understand….I have been watching too many US you tubers.
                #369572
                Roderick Jenkins
                  @roderickjenkins93242
                  Hi Matt,
                  Module is the metric way of specifying gears. There is a direct equivalent to DP sizes, just divide 25.4 by the Module. Thus M1 is 25.4DP and M.4 is (25.4/0.4) is 63.5. The tooth form is still involute but if you use Module gears you will need to change the design to cope with the size of gears you will cut although, e.g. 0.8M at 31.75DP is probably close enough to 32DP not to be a problem. You will note also that the cutter number is the other way round from the DP (Brown and Sharpe) notation where a #1 cutter >135.
                  HTH,
                  Rod
                  Way, way too slow – sorry to reiterate the good advice above.
                  Edited By Roderick Jenkins on 29/08/2018 15:13:15
                  #369592
                  Mark Rand
                    @markrand96270
                    The other significant point is that module involute cutters are 20°PA and DP involute cutters are 14.5°DP unless marked differently
                    #369600
                    Bill Davies 2
                      @billdavies2
                      No disagreement with Mark, but the 20° pressure angle was common when I started my apprenticeship in 1968. The 14-1/2° is to match the older machines that many of us have. Just a comment to reinforce the need to check.
                      Bill
                      #369601
                      larry phelan 1
                        @larryphelan1
                        Are those gear cutters any good ? Has anyone ever used them ? Might be interested in a set for myself
                        All replies welcome.
                        #369603
                        Emgee
                          @emgee
                          If you are substituting MOD gears for DP then however close the tooth size may be you will need to check the centre to centre dimensions to ensure correct meshing.
                          Emgee
                          #369605
                          Anonymous
                            Posted by larry phelan 1 on 29/08/2018 18:52:52:
                            I used some cheap, presumably Chinese, DP rather than module, involute cutters from a well known ME supplier when I was machining helical gears to check that I understood the mathematics. I knew I'd never use the cutters again which is why I bought cheap.
                            If I was cutting gears that mattered I wouldn't use them. My impression was they were rather more eccentric than they should be, and one had a visible wobble.
                            #369606
                            Roderick Jenkins
                              I've had a couple of sets of small Module gear cutters from CTC and have been perfectly happy with them.
                              Rod
                              #369613
                                I've used a few of teh RDG ones and they have done for the slow reving IC and steam engines. Also bought some even cheaper ones from the far east and at £5 a pop can be treated as disposable and they did seem to start loosing their edge after about 80 teeth (spaces) but the ones I did look OK to me. Expect they would last longer if use don brass rather than the steel I was cutting.
                                #369628
                                Mark Rand
                                  @markrand96270
                                  I've also used RDG's import cutters. In my case it was putting the teeth back on the feed gears for my shaper after machining all the broken ones off and building the remains up with 98% nickel welding rod. They worked perfectly well for the purpose.
                                  Edited By Mark Rand on 29/08/2018 21:34:02
                                  #369633
                                    I make my own single point cutters, slower but they do the job devil
                                    I've also used a homebrew rack form hob with success, which is as fast as using an involute cutter.
                                    Jens Eirik Skogstad 1
                                      @jenseirikskogstad1
                                      Module 1 is very easy to remember when you are creating the blank gearwheel also if you want to make 50 teeth gearwheel, then add 2 extra to 50 teeth will be 52 mm blank gear wheel (formula: (2+Z) x Module) and height of tooth is 2,25 mm. Module 1 is same as 3,1416 mm (PI) .
                                      Edited By Jens Eirik Skogstad on 30/08/2018 16:33:32
