Centre punch
Centre punch
Home Forums Beginners questions Centre punch
Viewing 25 posts - 1 through 25 (of 38 total)
  • #7391
    edintheclouds
      @edintheclouds
      edintheclouds
        @edintheclouds
        Hi,
        When using a centre punch to produce light pop marks I sometimes have trouble hitting the centre cross of the scribed lines, I'm using a jewellers loupe.
        Just wondered if anyone had any methods to produce a accurate centre mark every time?
        Les
        #171354
        frank brown
          @frankbrown22225
          The standard method is to "drag" the point of the centre punch along one line. A slight nick will be felt as the point drags over the second line.
          Frank
          #171355
          IanT
            @iant
            Some will tell you that they can feel the point "drop in" if you have a light touch. I wouldn't disagree but I've never managed to get consistent results using this method (but perhaps I'm just ham fisted). So for many years, I've used an optical centre punch for any 'fine' work and I get good results using it. It does need a reasonably wide area to rest on (or a similar piece to help 'balance' across) so it is not always usable in every circumstance. Generally however, it is my preferred way to get good results.
            Other methods include co-ordinate drilling (using some form of compound table or the milling machine) or if you really need accuracy – especially useful when you need the relationship between your 'holes' to be exact – then toolmakers buttons can be very useful.
            Hope this helps.
            IanT
            Edited By IanT on 03/12/2014 10:04:05
            #171356
            JohnF
              @johnf59703
              Spot on Frank but Les you may also want to consider an optical centre punch, just google it there are plenty, they work well as the eyesight dims with age !
              #171359
                You should be using a dot punch first which is more pointed, inspect the mark and if its off then lean the dot punch and hit it again to pull the mark to where you want it. When happy use the centre punch to deepen the dot punch mark.
                J
                #171362
                  Posted by IanT on 03/12/2014 09:52:51:
                  It's worth keeping a very fine-pointed [and nicely balanced] punch specifically for "locating" the position by feel … Hand pressure, or a very light tap with a Watcmaker's or Toolmaker's Hammer, is enough to produce a pinprick spot; which can then be enlarged with a regular Centre Punch or a Spade Drill according to taste.
                  Edit: Jason beat me to it.
                  P.S. … I find the spare points for Eclipse 220 Pocket Scriber very suitable as a fine punch. I bought a few at a good price, and keep three specifically for punching.
                  Edited By Michael Gilligan on 03/12/2014 10:25:55
                  Edited By Michael Gilligan on 03/12/2014 10:48:48
                  #171364
                  FMES
                    @fmes
                    Like John F said, try one of these, **LINK** or perhaps a cheaper version from eBay.
                    Problem solved.
                    #171366
                    edintheclouds
                      @edintheclouds
                      Many thanks to all of you for the advice, the optical centre punch looks interesting, its also down to practice and technique.
                      Cheers
                      Les
                      #171369
                        Les,
                        That's the problem that THIS FREE PLAN helps solve – get making!
                        Chris Trice
                          @christrice43267
                          Or consider a good quality automatic centre punch which doesn't involve hammers. I use mine all the time. Quick, simple and consistent.
                          #171377
                          mechman48
                            @mechman48
                            Ditto automatic centre punch… have it set for the lightest impact setting then check with loupe, adjust accordingly & follow up with heaviest setting … check again, then drill with #1 centre drill …
                            George.
                            #171378
                            Roderick Jenkins
                              @roderickjenkins93242
                              Tubal Cain recommends a little Archimedes drill with spear point bits for accurate centre marking. I've got a drill but no bits sad. I second (third?) the use of an automatic centre punch with a sharp point.
                              Cheers,
                              Rod
                              #171379
                              Nigel Bennett
                                @nigelbennett69913
                                I use a scriber as a centre punch to very gently mark the point – using a 12x loupe to ensure I've hit the right spot – and then bop it with an automatic centre punch prior to drilling. Use a small drill to start and open it up.
                                Obviously the scriber isn't one of those bent-end ones – or Tungsten Carbide tipped! – but a Priory PR127
                                They're on Fleabay (usual disclaimer)
                                **LINK** (I forget where I got mine now, but for under a fiver it's not expensive!)
                                #171380
                                mechman48
                                  @mechman48
                                  My centre punches…
                                  Tend to use auto punch as stated or the slim pricking punch underneath it.. if on black steel then will revert to short stubby 1/4" underneath that… the large one hasn't seen a hammer in years.. but it's there if I need it. As for use I hold it at an angle & feel for the tip to 'drop' into the crossed lines, raise it vertical, then press 'till it clicks or a light tap with a 8 oz. hammer if it's the prick punch.
                                  George.
                                  Edited By mechman48 on 03/12/2014 13:02:12
                                  Edited By mechman48 on 03/12/2014 13:03:41
                                  #171384
                                    Posted by Roderick Jenkins on 03/12/2014 12:38:12:
                                    sad
                                    I've never seen an automatic centre punch with what I would call a sufficiently sharp point.
                                    P.S. … Nice illustration of a spade drill [luxury Tungsten Carbide job] here.   [Similar geometry in Silver Steel should be adequate for marking-out]
                                    Edited By Michael Gilligan on 03/12/2014 14:52:17
                                    #171389
                                    Chris Trice
                                      @christrice43267
                                      The joy of most auto centre punches is they come apart easily allowing you to put the tip in your lathe and sharpen the point with a diamond lap although my one still has the original (sharp) tip.
                                      #171390
                                      Chris Trice
                                        @christrice43267
                                        I also do what Nigel does which is use the sharp scriber I'm marking out with and push it hard into the metal to make the tiniest locating mark for the auto punch to key into.
                                        #171394
                                        Gary Wooding
                                          @garywooding25363
                                          I made an additional point out of silver steel, which I sharpened to a nice point.
                                          #171397
                                          MM57
                                            @mm57
                                            <<From JasonB…You should be using a dot punch first which is more pointed, inspect the mark and if its off then lean the dot punch and hit it again to pull the mark to where you want it. >>
                                            I seem to recall someone posting a link to a paper written decades ago that covered centre punching, including rectification of initial mistakes (to which, I think, the above is not recommended – something to do with what the drill does when it meets such a rectified punch mark) to an almost anal level of detail. It was actually quite interesting reading
                                            But I can't find it – maybe a fellow forum elf can recall it?
                                            #171405
                                            IanT
                                              @iant
                                              My auto-centre punch very definitely seems to have a mind of its own – but perhaps I need to take a good look at it's point (and give it some TLC as Chris suggest).
                                              IanT
                                              #171419
                                              Ian P
                                                @ianp
                                                Whilst were on the subject of centre punches, can anyone direct me to a source of a replacement tip for an Eclipse heavy duty automatic (Model 172)?
                                                When I acquired mine the (screw-in) point had been sharpened many times and is now only about 8mm long (I imagine it should be about 30 or 40mm long originally) I suspect that only a few mm of the tip was hardened because when I sharpen it now it gets blunted after a few operations.
                                                Ian P
                                                #171427
                                                  Hi Ian,
                                                  At about £16 all-in I doubt they do spares.
                                                  I had the same problem with my 'cheapie', so I annealed the tip then rehardened and tempered it, but its getting a bit temperamental – due for replacement, methinks.
                                                    Posted by Neil Wyatt on 03/12/2014 22:02:40:
                                                    At about £16 all-in
                                                    … unless you buy from Farnell surprise
                                                    I guess you were probably thinking of the 171, Neil
                                                    172 is a much more interesting device [see the PDF on the Farnell link]
                                                    Edited By Michael Gilligan on 03/12/2014 22:33:19
                                                    #171432
                                                    Ian P
                                                      @ianp
                                                      I did a search and found tips for the model 171 (about £7+) but I'm not sure they are identical. I'm sure in theory the tips are meant to be replaceable, but its possible the manufacturers did not go to the trouble of making them available.
                                                      The one I have is ball shaped at the top and seems much less common than the cylindrical versions.
                                                      Ian P
