Cenetc 2A Horizontal Arbor Mill
Home › Forums › Workshop Tools and Tooling › Cenetc 2A Horizontal Arbor Mill
  • #447587
    martin cross 1
      @martincross1
      Having recently bought and now checked over the 2A, I see that the arbor is completely plain; as in there is no milled slot to take any form of locking key to stop the cutters from turning on the arbor. Is the Centec unusual in this area or do I need to get a slot milled into it. The arbor looks original, left hand thread to undo, 2MT on the taper, just no slot in it?
      I couldn't check before as the machine was set up and had a cutter in place which rotated etc, so I took it for granted that it was all there.
      #19595
      martin cross 1
        @martincross1
        #447591
        Thor 🇳🇴
          @thor
          Hi Martin,
          The lack of keyway in the arbor was discussed here.
          Thor
          #447598
          Dave Halford
            @davehalford22513
            As Thor link, there's nothing wrong with the arbour.
            #447603
            martin cross 1
              @martincross1
              That's good news. Thanks for the help!
              #447658
              Dave Halford
                @davehalford22513
                Have you changed the gearbox oil?
                #447669
                martin cross 1
                  @martincross1
                  Not changed it yet, but not used it either. Just run it up to check switches and gears etc. It appears to have a soft start on hi speed gears taking several seconds to reach full speed.
                  #447674
                  not done it yet
                    @notdoneityet
                    If it is a single phase motor, it is likely struggling to get to speed in top gear, particularly if the oil is thick and cold.
                    My 2B, with a one horse motor, would not start in high gear until warmed up. I changed it to a 3 phase motor and no problem since. The 2A may well have a 3/4 HP motor (particularly if it is original).
