Apologies to Richard for this going OT, but some interesting stuff (to me) has come up.
Michael: – I have used the white packing foam in the early days, but I wouldn’t really use it now – you are right that it seems to produce a very rough casting, and I had some problem with deformation, which seemed to happen during the pour. This took the form of apparent ‘bulges’ in the casting, as though the pattern had collapsed in a certain area. I have no explanation for this, but it has never happened with the ‘hard foam’ – incidentally, it comes in all colours, and I usually get mine at a builders merchant, its very cheap, and can be bought in single sheets up to about 1metre x 60cms, and up to 10cms thick – avoids the postal costs and delay on eBay. (will they send a single sheet through the post?). You can stick it together with a hot glue gun (plastic sticks). The info about the fumes and molten plastic, etc is interesting – I wondered if this was a cause of voids and the inclusions, but I had no way to prove it. Most users seem also to use the latex paint or thin plaster coat technique – I certainly get better castings using it – how would this affect the absorption of the styrene, etc into the sand?
Gordon W: This hard foam can be turned and sanded to a very smooth finish. There is usually a fair amount of stink and flames when you pour – really makes your eyes water – don’t lean over it when you do a pour.
Ian SC and TerryD. I have heard of using Borax as a flux – is this what you mean by washing soda?. Like you, I haven’t tried it, but its on the books for a try soon – I bought a big box full. I also have tried salt to prevent gas absorption, but results were a bit indifferent. The salt appeared to melt on top of the metal. I tried skimming it off just before pouring, but still got small pinholes and voids. I also tried leaving it on the metal, and just pouring ‘as is’, but again the results where indifferent – still some voids and inclusions.
I was told once that the purification tablets used for swimming pools could be used as a flux – may be this is where the floride (?) idea comes from. The tablets have to be plunged into the melt, so it melts and comes up through the metal (so I was told), so I bashed a piece of aluminium tune flat near the end, filled the last few centimetres with crushed swimming pool tablet, and flattened the end of the tube to keep it in place. This tube was then stuck into the melt. (very carefully!). After a few moments, there was a thick cloud of vile-smelling smoke and some bright white flames as the tube melted. I have to report that once again, no real conclusive results.
I have had conflicting advice on (over)heating – some say (as IanSC), that it shouldn’t be overheated (how do you tell without a pyrometer?). I have read that it should be heated until the metal is running freely (like mercury), then removed from the heat, skimmed, and left to stand for some moments until it develops a ‘claret-coloured skin’ on the top. It does develop a sort of coating if you do this, but to me it looks more like oxidation. Then what to do? – skim it again? pour it? – what?. And this makes no sense if a gas exclusion material like salt is used – so lots of confusion here.
The annoying thing is that on occasion, I have had the ‘perfect pour’ with no ‘remedies’ except skimming the dross – the casting is great, no holes, no inclusions and turns up a treat. I have tried reproducing the conditions as best I can (can’t control the weather though!), and the next pour is rubbish.
As IanSC comments, I have also read about iron containers, but where I live crucibles don’t exist. However, I tried stainless steel canisters – these seemed to work fine, but very quickly develop holes – the metal doesn’t melt – it sort of erodes away – and it is dangerous getting hot metal around your feet. Nonetheless, some good pours from it. I have also made steel crucibles from a chunk of steel pipe with a thick plate welded onto the end. These last much better than the stainless steel cans (but will still eventually develop holes). Again it is hard to say whether they affect the pour , sometimes the final casting was great, sometimes a dud.
Despite these problems, I still use the technique – it is often much quicker to make a casting than to fabricate a part, and quite often, pinhole voids can be ignored. When I started, I was surprised how easy it was to produce parts, providing you remeber that molten aluminium is dangerous if not handled carefully.
Regards, Keith.
