C3 mini lathe fixed steady spares.
Home › Forums › Workshop Tools and Tooling › C3 mini lathe fixed steady spares.
  • #608511
    Clive Farrar
      @clivefarrar90441
      Well being a bit heavy handed I have just split one of the special shaped studs that lock the brass shoes into place.
      Wondering if any one knows if and where spares are available?
      I have e mailed ARC tonight but thought i would ask here as well.
      Yes I know I could make one but prefer top do other jobs if I can.
      I can temporarily rob one from the travelling steady to finish my job but thought i would start the process of trying to find one now.
      Regards Clive
      #20759
      Clive Farrar
        @clivefarrar90441
        spare parts required
        #608512
        Paul Kemp
          @paulkemp46892
          As you have a lathe can you not find one inside a bit of bar you have in the shed?
          #608517
          Nigel Graham 2
            @nigelgraham2
            Paul –
            LOL! (Clive had said he'd prefer not to have to make it!)
            #608625
            Clive Farrar
              @clivefarrar90441
              ARC have responded. unfortunately in the negative.
              So at some point i will be digging out my 19mm bar stock and constructing a couple.
              May as well make two whilst i am at it as there is not a lot of meat on them after the M5 cross drill.
              However i have now learnt that they only need nipping up and not tightening.
              Regards Clive
              #608633
              not done it yet
                @notdoneityet
                Can you not just buy a couple of cap head screws or standard set screws for the job? Maybe even threaded rod? Perhaps a pic of this ‘special shaped stud’ might elicit some simple practical suggestions?
                #608708
                Hopper
                  @hopper
                  If you could use a cap (Allen) head screw it would be high tensile material and much less likely to break again.
