Broken Myford 1st Stud Gear Nut
Home › Forums › Workshop Tools and Tooling › Broken Myford 1st Stud Gear Nut
  • #18703
    Peter Wood 5
      @peterwood5
      #322027
      Peter Wood 5
        @peterwood5
        I have broken the hollow bolt which retains the 1st stud gear on my Myford Super 7.
        Can anyone advise me what sort of thread it is so that I can fabricate a replacement.
        Thanks.
        Peter
        Edited By Peter Wood 5 on 17/10/2017 21:51:48
        #322072
        Lambton
          @lambton
          Peter,
          The bolt you refer to is not hollow. It is a special with a head designed to engage in the slot in the quadrant to prevent rotation when tightening the nut. The shank is 1/4" diameter with a short length of 1/4" BSF thread. Not hard to make from a decent piece of steel eg from a large high tensile bolt
          Alternatively try one of the suppliers of second-hand Myford spares on EBay or if all else fails a complete stud assembly is available from ."New" Myford.
          Eric
          #322074
          Nick Hulme
            @nickhulme30114
            The two change wheel studs on my Super 7 banjo do have a blind bore with a cross hole to allow use of an oil gun to deliver oil to the bearing surfaces,
            – Nick
            #322085
            Peter Wood 5
              @peterwood5
              Eric and Nick.
              Thanks for your replies. By trial and error I found that a 2 BA oil nipple fitted perfectly. The 2nd change gear stud is also fitted with an oil nipple.
              The bolt was probably used instead of a nipple as it locks the retaining lever for the second gear. Anyway I will contact Myford to see if they do spares.
              Thanks again.
              Peter
              #322090
              KWIL
                @kwil
                Yes they do, Part 209 on diagram, A 2329/2 Gear Stud £24.00
