Bridgeport part size.
Home Forums Manual machine tools Bridgeport part size.
  • #403769
    bill ellis
      @billellis45274
      Hi all, a little help required, I'm in the process of rebuilding a Bridgeport and I need to find the size of a part.
      In the handwheel clutch on the quill housing assembly is a screw with a spring under it which bears on a ball bearing which acts as a detent for the up/down quill feed direction. Someone had fitted a ball bearing which is too large to go fully in the recess and thus was not doing its detent job. The ball bearing is part no ST132 (1402) and I wondered if anyone knows off hand what is the correct size of ball so I may get one from a ball bearing supplier. I may resort to measuring the recess but if anyone knows I would be greatful for the info.
      In case you wondered why I do not just order one from a bridgeport spares stockist this is the reason.
      Part ST132 steel ball, cost 37p, delivery £7.95 (yes I could not believe it so I rang them up and queried it), VAT £1.67, grand total £9.99 for a single ball bearing, I don't think so.
      Cheers
      Bill
      bill ellis
        @billellis45274
        #403775
        David George 1
          @davidgeorge1
          Hi Bill the ball is a 3/16 steel ball if you have the parts list it would tell you. Sent you s PM .
          David
          #403777
          bill ellis
            @billellis45274
            Thanks David, I thought it would either be 3/16 or 5/32. Off to the bike shop I go.
            Bill
            #403799
            bill ellis
              @billellis45274
              All sorted, found an old bicycle pedal in my box of bits, just happened to have 3/16 ball bearings in it. I now have a lifetime supply smiley
