Brazing gauge plate
Brazing gauge plate
Home › Forums › General Questions › Brazing gauge plate
  • #298132
    Martin Botting 2
      @martinbotting2
      Evening fell swarf makers!
      I have a project on the go where I would like to harden a scribing edge on a height gauge, I have some water quenching gauge plate and thought about silver soldering a bit to the foot. I would have used a bit of carbide if I had some but does the brains trust think using the gauge plate and then temper it after jointing and grinding it do the trick.
      Many thanks.
      #25234
      Martin Botting 2
        @martinbotting2
        #298135
          Quench while stillred hot from soldering then temper, I have done similar a few times for the latches on hit & miss engines
          #298191
          Martin Botting 2
            @martinbotting2
            Thanks Jason.
            I will give it a go and when my burnt fingers heal (always do it after a session with the blow torch) i will post up some pictures.
            #298193
            Tony Pratt 1
              @tonypratt1
              What's wrong with making a hardened scribing edge then soft soldering to height gauge extension bar or make a complete foot from gauge plate?
              Tony
              Edited By Tony Pratt 1 on 15/05/2017 10:13:13
              Edited By Tony Pratt 1 on 15/05/2017 10:13:55
              #298199
              MW
                @mw27036
                Posted by Martin Botting 2 on 15/05/2017 10:05:28:
                Thanks Jason.
                You might want to be a little more careful, I've had a 3rd degree burn before and they never fully heal !
                Michael W
                #298202
                Nick_G
                  @nick_g
                  Posted by Michael-w on 15/05/2017 10:43:45:
                  Michael W
                  Was this heat on your brain caused by thinking. ?? winkwink
                  Nick cheekywink
                  #298212
                  MW
                    @mw27036
                    Posted by Nick_G on 15/05/2017 10:53:37:
                    Michael W
                    Nick cheekywink
                    Cheeky monkey, well I know it certainly couldn't have come from the warmth of your heart! cheeky
                    Michael W
                    #298222
                    Martin Botting 2
                      @martinbotting2
                      My fingers get badly burned just by all the head scratching I do. When I take my boots off to get past 9 while counting the bandages get in the way doing the laces up.
