Posted by Martin Kyte on 02/11/2017 10:57:59:
Hi Roger
Flat top to the tool and hone to a fine polish. The finish will only be as good as the finish on the tool so make the effort. Cut dry as has been stated.
If you are drilling stone your drills so that there is no rake or they wil grab. This can be done by rubbing the cutting tip on a stone or small diamond card parallel to the drill axis. You will want to keep a set for brass.
regards Martin
If you've a bench grinder with a fine (- ish) wheel, you can use the side of the wheel to grind a zero-rake platform on the drill lip no more than about 1/2 mm wide. Then you can quickly return the drill to standard if it's too fiddly or expensive to keep a separate set for brass.
I've always worked on about 300 ft/min or 100 m/min for the most usual CZ121 brass, which is free-cutting with a discontinuous chip (bits go everywhere as has been said!). There are tougher brasses like CZ106 which I've always machined a bit more like mild steel – about 100 ft. or 30 m/min, a bit of top rake and sometimes bundling swarf ribbons. All for offhand-ground HSS tools.
