Brass and Paint
Brass and Paint
Home › Forums › General Questions › Brass and Paint
  • #44255
    PIERRE COURBOULEIX
      @pierrecourbouleix60628
      A simple question (?). May be of some interest to all of us!
      How to pepare a brass part to be painted.
      What kind of surface preparation before coating,
      What kind of primer to use ? ? ?
      Thank you for your kind reply
      Pierre Courbouleix – F75015 PARIS
      #21637
      PIERRE COURBOULEIX
        #44263
        charles mortimer
          @charlesmortimer72298
          hallo pierre
          before priming brass  its a good idea to remove the shine using fine wire wool once that is done  you require (an etch primer)  and idealy it should be sprayed on evenly and thinly   one coat is enough    the finishing coat can go directely on top of the etch primer and that has to be put on thinly   and also best sprayed on . if put on to thickly and the item gets a knock  chips in the paint will appear    –  etch primer helps to stop this problem   but needs to be done well   pratice on a sheet of aliminum   dont use a brush use a compressor and small spray gun  and thin the paint
          charles
          #44362
          Niloch
            @niloch
            The following advice is to be found at:
            Brass, copper, aluminium and nickel silver, in fact all non-ferrous metals should be etch primed before applying any subsequent coats of paint. These metals have an oxide layer which paints do not adhere to very well. Even if abraded with abrasive paper, the oxide layer reforms within 2 or 3 seconds!! Etch Primer has an acid in it to microscopically eat through the oxide layer and into the metal thus providing a key for the paint.
            #44902
            The Mad Professor
              @themadprofessor
              I have found that putting a thin coat of genuine shellac in methylated spirits onto the clean aluminium, brass etc, and letting it dry, provides a good surface for the paint to stick to.
