Boxford drill parts
Boxford drill parts
Home › Forums › Beginners questions › Boxford drill parts
  • #462682
    Adrian L
      @adrianl82643
      Hi all, newbie here.
      I might purchase a boxford pd8 I've seen. Is it possible to obtain replacement parts for it should the need arise? For instance if the chuck doesn't run true etc.?
      I would be purchasing unseen in the flesh so to speak.
      Thanks in advance,
      Adrian.
      #10159
      Adrian L
        @adrianl82643
        Renewing parts
        #462683
        Adrian L
          @adrianl82643
          HI again. I should add the Boxford drill looks to be from the 1970's.
          Cheers,
          Adrian.
          #462696
          DC31k
            @dc31k
            I think if you put 'boxford PD8' into Google, you might receive some enlightenment.
            Alternatively, start here:
            https://www.model-engineer.co.uk/forums/postings.asp?th=70616
            #462805
            Adrian L
              @adrianl82643
              Hi DC31k, I posted here first because there was a fair bit of interest in the drill and I wanted to snap it up. I tried ringing Boxford but there was no answer initially but eventually I got through to a guy in parts department who directed me through their website and it looks like parts availability shouldn't be a problem which is a bit of a relief.
              I see there is someone on this site who has done some restoration work on his Boxford drill so if the drill I receive does need some remedial work I can hopefully get some advice from here.
              I'm looking forward to using a good quality drill made here rather than a cheaper made chinese drill.
              Adrian.
