Boxford blues
Boxford blues
Home Forums Manual machine tools Boxford blues
  • #72849
    Tim Hadleigh
      @timhadleigh69425
      Hi, just bought a very nice boxford CSB lathe, dated 1963. Have read “know your lathe” but am mystified as to how to proceed. For example, the book names the swing lever on the front of the headstock as a swing gear. What is that for and what position should it be in when switching on?
      Next there is a small lever flush with the back, left side of the headstock housing…what is it?
      I have tumbled the red knob in front of the gear box, which is a reverse gear selector – i assume it should be in neutral when i switch on and l wont move it while the motoris running.
      Sorry to sound so dumb but any help appreciated.
      Tim
      Tim Hadleigh
        @timhadleigh69425
        Seeking advice on some basicsof my new boxford lathe
        #72852
        _Paul_
          @_paul_
          The lever on the front in conjunction with the small lever to the L/H side of the headstock operate the Backgear.
          The red knob (if I read you right) is the tumbler reverse and governs the direction of the carriage when the leadscrew half nuts or apron feed are engaged.
          I leave mine engaged in the direction I use it most (cutting toward the headstock) I do also (Rightly or wrongly) change it while running .
          Paul
          #72854
          michael howarth 1
            @michaelhowarth1
            Steady on Tim…. there was a chap on the forum the other day who didn’t know what PB was and there was hell to pay…..now you’ve gone and bought a lathe and don’t know how it works!!! Stand by for some flak mate.
            #72901
            Tim Hadleigh
              @timhadleigh69425
              Thanks Paul,
              So where should the swing lever at the front and the rearmost lever be positioned when starting it up?
              Tim
              #72903
              MAC
                @mac53652
                Hi Tim,
                Does your lathe not feature a speed table anywhere with diagrams of lever positions? My Boxford has a table that’s easy to follow.
                The levers you mention are moved together as Paul said (I mean when you move one, you move the other also). So there are only two possible combinations – not 4 as you might perhaps think. For low speeds you will have the front lever to the left, and the side lever pulled forward. The opposite positions for high speeds.
                Must only be moved when turned off. Paul feels comfortable moving the reverse lever under power, which I’m not questioning, but I always move this while the lathe’s off too.
                Cheers.
                Edited By MAC on 05/08/2011 10:10:59
                #72906
                Tim Hadleigh
                  @timhadleigh69425
                  Thanks Mac, thats a great help and all makes sense.
                  No chart on the front. It is a ’60s machine that has obviously been painted and the charts not replaced. In lovely condition though. Will try to source a photo of the chart and stick it on the front.
                  With ref to Mick H’s comments, l am reasonably proficient at using a lathe, just not a boxford and only a fool would turn it on and crash the gears.
                  All the best
                  Tim
                  #72913
                  RichardS
                    @richards31161
                    Tim
                    Three links:
                    Worth joining for the files section alone (there are PDF’s of the various charts and plates).
                    Boxfords in general:
                    http://www.lathes.co.uk/boxford/page16.html
                    CSB Boxford specific:
                    Richard
