Goodonya Katan.
Although down here we are nine hours ahead of most of you people, the following notes are beginning to lag behind.
However, having overlooked a third issue mentioned in the NGP link and mentioned more than once in this forum, is that the saddle etc. is driven by an offset force from the apron, whether it be the leadscrew or the rack and pinion. The tool will ‘lift’ after a (forward) surfacing cut (or dig in after boring), thus illustrating that the saddle indeed rotates, albeit slightly.
After more than 60 years of regular use (not all mine), by the time I sold the ML7 it wasn’t even necessary to test with a dial indicator. There was also obvious bed wear closer to the chuck than the mid-section and tailstock end that no amount of gib adjustment could alleviate.
Irrespective of the dimensions of the workpiece and tooling (e.g. boring bar), the old saddle of my ML7 was clearly worn.
Aside from the stress/strain pathway (tool-tip to workpiece), where deflections accumulate, I commend a ‘glance’ at the principle formulae (particularly cantilevers) of beam theory where the dimensions are raised to some power, i.e. cubed and indeed to the fourth power.
Keeping these in mind for both tooling and workpiece, may bring a clearer understanding of how stuff bends, twists, and tries to get out of the way.
I might add – ‘Know your machine’.
Enjoy your hobby, I did
Sam
Edited By Sam Stones on 10/07/2020 20:46:25
