Blue steel screws
Blue steel screws
Home Forums Materials Blue steel screws
  • #339688
    Daniel Maier
      @danielmaier47990
      Does anyone know where to get some blue steel screws, like the ones watchmakers use in BA 10 ? I know there is plenty of instructions on YouTube how to make them, but I need quite a few and therefore try to get them ready made?
      Daniel Maier
        @danielmaier47990
        #339784
          Hello Daniel,
          Welcome to the forum. I think the reason there are so many 'how to' guides is because they are so hard to buy.
          Most clockmakers would say commercial screws are too rough and ready and want to polish them up before bluing as well.
          Steve Crow
            @stevecrow46066
            Hi Daniel
            If you want to blue your own screws – which you will probably have to – you will have to find plain steel screws ie. non stainless/ zinc plated. This can be tricky.
            If you are looking for cheesehead, by far the best steel BA screws I've found are from Macc Models.
            I recently had to polish and blue around 40 12BA screws. It really didn't take that long. Although not quite watchmakers quality, I'm very pleased with the result. I have to do another 40 soon.
            How many screws do you need to do?
            If you're interested, I can tell you how I did it and maybe post some photos.
            Cheers
            Steve
            #339946
            John Reese
              @johnreese12848
              Check out Clickspring's You Tube videos. He makes the screws from scratch, then polishes and blues them. You can probably start with commercial screws and use Clickspring's technique for polishing and blueing them.
              #339956
              vintagengineer
                @vintagengineer
                Removing zinc plating is really easy. You need to make a saturated solution of white vinegar and table salt. Then drop your nuts and bolts into the solution overnight, then they come out nice and clean!
                #339983
                john carruthers
                  @johncarruthers46255
                  don't step on them
                  #340065
                  Daniel Maier
                    @danielmaier47990
                    Thanks for your replays, I think I will end up blue this little screws myself, or go to a watchmaker to blue them for me.
                  Home Forums Materials Topics
