Blotters on Diamond Grinding Wheels
Home Forums General Questions Blotters on Diamond Grinding Wheels
  • #25713
    Brian H
      @brianh50089
      #333428
      Brian H
        @brianh50089
        I think the answer to my question is NO, you don't need blotters on diamond wheels, the ones made from aluminium with a diamond coating, but does anyone know differently?
        #333440
        Chris Evans 6
          @chrisevans6
          I don't know the official answer but I never use them on aluminium diamond wheels.
          #333448
            No, the blotters are to make sure you don't have any stressed points on a bonded wheel.
            #333463
            mechman48
              @mechman48
              Posted by Neil Wyatt on 22/12/2017 19:10:34:
              ​+1 , Also provides a means of identifying what type, rpm, abrasive, grain, grade, structure & bond etc. that the wheel consists of.
              George.
              #333464
              Simon Williams 3
                @simonwilliams3
                It's a long time since I did the course, so I've been looking at the HSE Guidelines which have superseded the Abrasive Wheels Reg's under PUWER, and a "plate mounted wheel" is one of the specific exemptions from the use of blotters.
                If I've understood the description, a plate mounted wheel is one where the abrasive grains are bonded to a backing plate, and the drive clamping force acts on the plate and not on the abrasive. That seems to describe a bonded diamond wheel pretty much spot on.
                Common sense says that a blotter doesn't add anything to the mounting security of this type of wheel, so hopefully I'm reading this right.
                #333466
                Brian H
                  @brianh50089
                  Many thanks all, for the answers, I'll ignore the blotters on aluminium backed wheels.
