Blackening mild steel
Home Forums General Questions Blackening mild steel
Viewing 25 posts - 1 through 25 (of 58 total)
  • #24094
    Rainbows
      @rainbows
      Rainbows
        @rainbows
        So all quick change toolposts tend to have this sort of blackened finish to them and I was wondering if there was a hobbyist friendly way of doing it. I think I remember a video of putting hot steel into dirty motor oil in order to blacken it but I can't think where I saw it now.
        #203483
          The oil doesn't need to be dirty (contaminated motor oil causes several nasties, notably testicular cancer), I use rapeseed oil. Heat to a good black heat and drop in. Cover to prevent flames. Repeat.
          Bazyle
            @bazyle
            There have been some cold blackening treatments on sale from ME suppliers in the past. Not sure about now.
            #203499
            Michael Topping
              @michaeltopping17870
              Blackgates do a cold chemical blacking kit that works quite well, but I think when I have used up the chemicals I have I will go back to heating to black heat and oil quench. To me it seems to be longer lasting.
              Michael
              #203505
              Chris Denton
                @chrisdenton53037
                The Caswell kit seems to work ok, I've done hundreds of parts with it.
                #203519
                jaCK Hobson
                  @jackhobson50760
                  Posted by Neil Wyatt on 07/09/2015 21:23:05:
                  One advantage of getting old is that you reduce the chance of this disease (probably because of the increasing chances of developing something else).
                  It's a good idea to do it outside and be prepared for significant flames. It is also then much easier to avoid inhaling most of the nasties.
                  I was taught to use old engine oil at school
                  Edited By jaCK Hobson on 08/09/2015 08:26:24
                  #203520
                  donkey
                    @donkey
                    I blacked a number of items with the motor oil method, heat and dip (about 20 items) 30 years ago although in a box they have been stored in a very damp garage and only one item shows signs of rust.
                    brian
                    #203523
                      @mike89748
                      I seem to recall reading somewhere that most modern motor oils contain additives which supress blacking. I've had good results with cheap supermarket own-brand margarine, but it does make the workshop smell like a fire in a chip shop…
                      #203525
                      Douglas Johnston
                        @douglasjohnston98463
                        I've tried a number of different oils in the past for blacking and all work pretty well. Like Neil I now use rapeseed oil (just the cheapest type from the supermarket ) and get consistently good results.
                        I tend to heat to dull red which may be a higher temperature than is needed, I must experiment at lower temperatures to see if it works just as well.
                        Doug
                        #203526
                        Gordon W
                          @gordonw
                          I use old engine oil, diesel is better as more black in it. Just keep all your working bits well away. Also does help with rust prevention.
                          #203527
                          KWIL
                            @kwil
                            "Black-it" from Pixel Plus also works well.
                            #203530
                            Ajohnw
                              @ajohnw51620
                              I've never done it but saw a demo of oil blackening to prevent rusting at school when I was around 12 years old.
                              The item was heated with a torch and oil squirted on with an oil can – oil ? what ever was in the oil can. The result was a pretty thick coating.
                              Ian Hewson
                                @ianhewson99641
                                As I remember, testicular cancer was caused not by inhalation, but by oily hands when going for a pee, or rags in overalls pockets.
                                #203543
                                jason udall
                                  @jasonudall57142
                                  Used engine oil…
                                  Apart from the witches brew poured into the engin..you get to share any unburnt fuel residue and burnt fuel residue. ..
                                  A) an inconsistent start point.
                                  B) all sorts of nasties. .not least from synthetic oils breakdown products..
                                  Best spring for some fresh oil…either a culinary type ( got to be harmless right?) Or a known mineral oil.
                                  Just a hint…a bigger bucket( of oil) will take more hot metal to elevate temperature to flash point…ideal bucket..deep and narrow..part becomes 100% immersed “instantly”..coaxing the metal in is the best way to light the oil.
                                  #203551
                                  Gordon A
                                    @gordona
                                    I use linseed oil; heat item to be blackened to dull red and plunge into oil…outdoors of course. Very good results so far.
                                    #203559
                                    Ajohnw
                                      @ajohnw51620
                                      Posted by Ian Hewson on 08/09/2015 10:36:52:
                                      Mostly due to mist and splash onto overalls as I understand it, possible wiping hands on overalls too, oily rags in pocket etc.
                                      Gordon W
                                        @gordonw
                                        Many of the health risks in the past were down to poor hygiene. Not surprising really when you think about, not many even had a proper bath, washing machines very rare. The same clothes worn all week, etc.
                                        #203598
                                        Rainbows
                                          @rainbows
                                          Would it be best doing this before tapping? Wondering how it would affect the tapped holes of the toolpost
                                          #203599
                                          Fowlers Fury
                                            @fowlersfury
                                            Rapeseed or sunflower oil from the supermarket is cheap enough not to bother with old engine oil.
                                            Once done, rub the item all over with black shoe polish – allow to dry & polish off. It will help to delay any subsequent rusting and looks good.
                                            You can also get a pretty good black appearance on an item you might not want to heat by purchasing some "Gun Blue". Follow the instructions carefully with regard to degreasing and certainly use the shoe polish afterwards as the black is only a "few molecules" thick.
                                            #203600
                                            KWIL
                                              @kwil
                                              If you use Black-It and similar selenium based products, which include commercial gun barrel blacking products, it changes the surface and does not merely add a layer of burnt oil (aka oily carbon) to the surface. This oily layer can be quite thick. This way threads are largely unaffected.
                                              #203601
                                              Maurice Cox 1
                                                @mauricecox1
                                                If you decide to use vegetable oil, be careful what it is. There have been recent warnings on the television cooking programmes not to use two particular oils for cooking if it involves high temperatures, as the oil changes and gives of dangerous fumes. I think the oils were corn oil, and sunflower oil. Can't remember what the effect of these fumes is, but they were sounding very serious about it. Just thought I should mention it.
                                                Rergards Maurice
                                                #203602
                                                Rainbows
                                                  @rainbows
                                                  Tried generic veg oil on a bit of round bar. Mottled from very dark grey to jet black. Might have got it all jet black but using a small Sievert blowlamp was somewhat slow and at that point I was pretty sure it was working. That said I'm gonna try it on motor oil to compare speed and finish.
                                                  I'm gonna have to make or buy a furnace though. The toolpost is close to a 70mm cube of steel and I don't feel like heating that with a blowlamp.Alternatevly anyone feel like selling one of those really big blowlamps?
                                                  #203611
                                                  Muzzer
                                                    @muzzer
                                                    Well used engine oil is considerably more hazardous than new. It has absorbed lots of nasties from the exposure to and absorption of combustion products. The normal route into the body is by ingestion and results in cancers of the gut, bowels, rectum, scrotum etc. There are better ways to go than being eaten up, starting from inside your ringpiece.
                                                    Similar pathway for "new" petrochemicals but tend to be less nasty. Even simple petroleum derivatives contain small amounts of nasties. Best stick to plant oils if you can.
                                                    My late dad was an industrial toxicologist and his library made interesting reading.
                                                    Murray
                                                    #203624
                                                    Nigel McBurney 1
                                                      @nigelmcburney1
                                                      Try a local gunsmith,they used to sell bottles of gun blue,and I think that it was also available in black. Large packs of blacking chemicals are expensive (See Frost Auto).
