Black anodised steel????
Home Forums Beginners questions Black anodised steel????
  • #436921
    Chris TickTock
      @christicktock
      Looking at a 10mm motor spindle adapter on Ebay I see they describe it as made of steel and black anodised. Now this product comes from Hong Kong.
      My question is I am led to believe anodising carbon steel is a bad thing as it promotes rust whilst on aluminium it is a good thing. So if the metal is steel would it be a safe bet the metal is a mild steel or possibly not steel at all??
      Chris
      Chris TickTock
        @christicktock
        #436923
        Jeff Dayman
          @jeffdayman43397
          It is possible to apply a black coating on steel by several methods, but it is not anodizing. You will find anodizing on aluminum.
          #436924
          duncan webster 1
            @duncanwebster1
            Parkerising is one method of bluing and applying rust resistance
            If anyone has a recipe for the gloop you heat the component in I'd be interested. I've got one for bluing which sounds distinctly dodgy, boiling solutions at well above 100C
            Edited By duncan webster on 11/11/2019 23:03:45
            #436931
            pgk pgk
              @pgkpgk17461
              I suspect the black coating being called anodising in the original question was just "translator's license"
              #436935
              Brian H
                @brianh50089
                I believe that the process in sometimes called 'Blackodising' which may explain the confusion.
                #436938
                Clive Hartland
                  @clivehartland94829
                  While working on large gun recuperators the internal parts were given a Black Chrome finish, they were first copper plated then immersed in a hot bath that had the chemical mix in it. After a time the items came out and the copper was brushed off leaving a lovely shiny black finish, supposedly rust resistant.
                  I have tead that Browning shotguns had black chrome bores to stop rusting.
                  #436939
                  Clive Hartland
                    @clivehartland94829
                    Sheradising is another dark.black finish you see on twist drills, this done with steam at 500c.
                    Edited By Clive Hartland on 12/11/2019 08:12:22
                    #436948
                      Posted by Chris TickTock on 11/11/2019 22:23:18:
                      Chris
                      Apologies if I've misunderstood but two things may be mixed up here:
                      1. Does blackening steel promote rust?
                      2. Is the motor spindle adaptor made of a suitable metal?
                      The information provided in the advert isn't enough to answer either question.
                      1. Steel or any other metal can be coloured by any of several processes, ranging from a dab of paint up to the elaborate industrial process described by Clive. Colouring may be purely decorative or intended to resist corrosion. The best protections are achieved with hot nasty chemicals. Home workshop methods are less effective because we don't have the ways and means. Plenty of commercial blackening is thin and temporary. The purpose of blackening matters too: home blued steel would be risky on a closely inspected decorative item like a delicate clock where even minor blemishes matter, but perfectly acceptable on rough functional items. In practice an adaptor would have to get very rusty before it mattered!
                      2. What the Hong Kong item is made of is unknown. As steel is cheap and strong, it's almost certainly steel. Mild-steel would be 'good-enough' for hobby use, but more likely the maker would use a tougher engineering steel because they aren't much more expensive than mild-steel. It might be a very tough alloy steel or a stainless. But who knows? The only way to find out would be to contact the maker or have the item tested.
                      Always worth asking is 'does it matter'? There are two bad mistakes in engineering. One is thoughtlessly buying only on cost and convenience, the other is to insist on only the best. The first is bad because it risks wasting time and money on tools and materials that aren't fit for purpose. The second sin is more serious because best is the enemy of good. Over-engineering pointlessly wastes time, talent and money on a grand-scale. It's a black-hole.
                      Only individuals can decide what their goals are! In your place I'd buy the adaptor and try it because my priority would be getting the tool working irrespective of look or long-life. It will probably be OK. If not, understanding why the adaptor is unfit for purpose is useful learning.  Others enjoy good tools for their own sake, or like to get things right first time.  Whatever floats your boat, but it pays to understand why you want it!
                      Edited By SillyOldDuffer on 12/11/2019 11:04:26
                      #436955
                      Chris TickTock
                        @christicktock
                        Thanks for all the posts. The reason I need to know is trying to evaluate whether I could machine the adapter if necessary to alter it.
                        Chris
                        #436956
                        Phil P
                          @philp
                          Could you not make your own spindle adapter, then you know for sure what it is made from ?
                          Phil
                          #436962
                            The real answer to your question is that he listing is dodgy.
                            Whether or not this may reflect on the quality and accuracy of the component is your call… the quality of such goods ranges from the perfectly OK, through rejects with cosmetic flaws, to chocolate teapot standard.
                            Chris TickTock
                              @christicktock
                              Probably will end up doing so but bare in mind the adapter is cheep and if easily machinable and it fits well on the spindle altering the other end may be the easiest option for me having as yet not done any precision boring. What I mean precisely is lets say the motor spindle is 10mm then to make a good fitting spindle adapter questions arise:
                              1. What bore should I make the adapter?
                              2. Do I pilot drill to say 8mm then use a boring tool to achieve the final diameter?
                              3. Is mild steel adequate for this purpose?
                              4. Is using 2 grub screws to fix the adapter to the spindle adequate?
                              Chris
                              #436968
                                Posted by Chris TickTock on 12/11/2019 13:31:21:
                                Forget about numbers, tolerences and trying to measure them, make the bore to fit the motor shaft, it should need light hand pressure to push it on and if right you will feel a cushioned piston effect due to trapped air in the hole. Picking up the motor shaft downwards and the adaptor should not fall off
                                Yes
                                Yes
                                Unlike the ones on e-bay put the two screws at 90degrees to each other and file some flats on teh shaft for them to bear against
                                Chris
                                #436974
                                Chris TickTock
                                  @christicktock
                                  Posted by JasonB on 12/11/2019 13:43:40:
                                  Yes
                                  Yes
                                  Chris
                                  Thanks Jason, I have now thanks to your post something to work from.
                                  Chris
                                  #437026
                                  Howard Lewis
                                    @howardlewis46836
                                    At the risk of being called a pedant.
                                    As already said, Anodising is only applicable to Aluminium. Chromic acid is one of the constituents of the electrolyte bath. As the name implies, the Aluminium is the Anode.
                                    Sheradizing is heating steel in a Zinc powder, and is form of low er temperature Galvanising. (Galvanising is dipping the ferrous component into a bath of molten Zinc ). Strange calling it that, since no galvanic (electrolytic action by an external source is involved, just ion exchange between the two metals )
                                    Physically akin to, but not the same as, Carburising, which combines Carbon with steel, so that it can be heat treated to harden it.
                                    The Zinc becomes, effectively, a sacrificial anode, in preference to the ferrouis material.
                                    Parkerising (Parcolubrising) is less of an anti corrosion coating and more of a self lubricating finish. It is applied by immersing the steel or ferrous item in a vat filled with hot / boiling fluid. I suspect that phosphoric acid will be a major constituent.
                                    Dipping in oil after Parkerising will greatly enhance protection against corrosion.
                                    Purely a comment:
                                    I would advise MOST strongly against using this, but Conentrated Nitric acid is such a violent oxidising agent that it will produce a protective film of oxide on Aluminium or Iron, if they are dipped in it. A dangerous process!.
                                    As Blue Peter used to say "DON'T try this at home".
                                    #437055
                                    John Olsen
                                      @johnolsen79199
                                      The reason galvanising is called that is because the Galvanic action takes place when the protected metal is exposed to wet corrosive surroundings. When this happens, the action is such that the zinc is consumed and the steel is protected. So if galvanised metal is used in salt water, the zinc will eventually be consumed.
