Best material for gib strips
Home Forums General Questions Best material for gib strips
  • #346967
    Martin Dowing
      @martindowing58466
      Which material is best for gib strips of slides?
      Martin
      Martin Dowing
        @martindowing58466
        #346970
        Andrew Tinsley
          @andrewtinsley63637
          I have used ground steel stock and have had no problems thus far.
          Andrew.
          #346972
          Emgee
            @emgee
            From similar past posts gaugeplate seems to be a good choice.
            Emgee
            #346979
            HOWARDT
              @howardt
              In my working life in machine tool design taper gibs were always made of a metal softer than the ways. Hardened ways used cast iron gibs, cast iron ways used cast iron or brass gibs. Wear will occur to the softer metal over time. At a minimum use like materials for slow moving surfaces. Also consider the aspect of galling if too soft a material is used and galvanic action of dissimilar metals although this is unlikely unless water based cutting fluids are used.
              #346986
              John Reese
                @johnreese12848
                South Bend 9" and 10K lathes used steel gibs. It looks like cold rolled flat with the edges bevelled.
                #347005
                Martin Dowing
                  @martindowing58466
                  Many thanks for comments and opinions.
                  Seems that best approach is to use perhaps cast iron gibs as Howardt suggests and if for whatever reason this cannot be done some gauge plate steel will do, particularly if slide is rarely used.
                  Martin
                  #347234
                  mechman48
                    @mechman48
                    I replaced the abortion of a gib strip on my WM250V-F compound slide soon after I bought it. I used brass plate to make new gib, as the compound slide is a casting, & not used often the different materials shouldn't be a problem … Original gib strip… surprise
                    New brass gib strip …
                    … works just fine, also replaced one of the adjusters with a locking screw…
                    George.
