Baty gauge repair
Baty gauge repair
  • #33697
    John Hall 7
      @johnhall7
      #500411
      John Hall 7
        @johnhall7
        Hi, has anyone dismantled a Baty dial indicator?
        i want to remove the front glass and bezel to clean the face…There is a small hole in the bezel and when turned, 4 small slotted screws are revealed. Do these need to be removed to allow the glass and bezel to come off?
        cheers John
        #500420
        gerry madden
          @gerrymadden53711
          Just so happens John I did one last week. If I remember mine only had three screws and I could get away with removing two for dismantling. However when in came to reassembly I took out the third one too as as it made it easier to get the dial and everything else in the right place with an even compression.
          G.
          #500429
          John Hall 7
            @johnhall7
            Thanks zGerry…much appreciated..
