Barclay Well tank as in Model Engineer
Home Forums Drawing Errors and Corrections Barclay Well tank as in Model Engineer
  • #329224
    Anthony Simmons
      @anthonysimmons29131
      Hi all. I have just started building the Barclay Well tank loco which is being serialized in Model Engineer. I have a problem with the measurements for the weighshaft. If you follow the drawing it brings the weighshaft too close to the brake hanger. Looking at the photos in the Model Engineer its further away. Are there any other builders who have come across this? I’m thinking the measurement from the centre of the front axle to the weighshaft should read 7 5/8 and not 7 5/16 as drawn. Any help appreciated. Anthony
      #38813
      Anthony Simmons
        Drawing error
        #330690
        Anthony Simmons
          Hi. I now have the correct dimention if there’s any other builders wanting to know. The drawing should read 7 11/16 from the centre line of the front axle to the weightshaft hole centre. Anthony
