Ball Races and ‘Brinelling’ (whatever that is).
Home Forums The Tea Room Ball Races and ‘Brinelling’ (whatever that is).
Viewing 14 posts - 26 through 39 (of 39 total)
  • #532587
    Howard Lewis
      @howardlewis46836
      When US automakers first started shipping cars and pick ups by rail, often stacked near vertical, wheel bearings suffered premature failure due to brinelling. because of the Static Load + Vabration during transit.
      Loading in the normal horizontal mode (load spread over four rather than two wheels ) and improved suspension of the wagons (freight cars ) improved the situation.
      Tim Stevens
        @timstevens64731
        The parking of bells in the mouth down position is (I understand) also intended to foil the deliberate efforts of small boys, and the careless misunderstandings of others, as the ropes just hang there and anyone wandering by could just pull, causing a lot of clanging and consternation – especially if a service was going on.
        Cheers, Tim
        #532640
        not done it yet
          @notdoneityet
          Posted by Douglas Johnston on 08/03/2021 13:26:42:
          I wonder if the huge bearings on wind turbines suffer from this when the blades are stationary on calm days. There must be a huge static load under those conditions.
          Doug
          Here we go again. Yet another fantasy problem for our wind turbine haters.
          The cause is known. Engineers are not stupid once they are aware a problem they take remedial action. Wind turbines are designed to last twenty five years without swapping bearings at regular service intervals. They are likely not stationary – there is probably some tiny electric drive barring the rotor gently, while the turbine is out of service.
          #532641
          not done it yet
            @notdoneityet
            Doug
            Here we go again. Yet another fantasy problem for our wind turbine haters to latch onto.
            The cause is known. Engineers are not stupid once they are aware a problem they take remedial action. Wind turbines are designed to last twenty five years without swapping bearings at regular service intervals. They are likely not stationary – there is probably some tiny electric drive barring the rotor gently, while the turbine is out of service.  Or a high pressure oil pump working away steadily to ensure the bearings are sufficiently lubricated to avoid metal to metal contact.
            Edited By not done it yet on 08/03/2021 19:51:23
            #532645
            Bodger Brian
              @bodgerbrian
              Posted by duncan webster on 08/03/2021 11:38:25:
              Posted by Nicholas Wheeler 1 on 07/03/2021 19:12:32:
              Posted by duncan webster on 07/03/2021 18:21:29:
              Church bells rotate +- half a rev plus a little bit. The little bit is vital, get it right and you can park the bell mouth up, a fraction more and you break the stay, the rope (known as a Sally) disappears up through the hole in the ceiling. Hopefully the campanologist has let go.
              ???? Every one I've seen has gone from mouth upright, round to upright again. There are plenty of belfry videos that show this. The stay is about another 10 degrees past vertical. It shouldn't break if you just bump it, although learning not to do that is the first thing a beginner should be taught once they're ringing without help.
              The rope is called the rope; the woollen grip for the handstroke is the sally.
              Normal parking position is mouth down, at least it was when I was involved (many moons ago), so rotation +- half a rev plus a little bit seems a reasonable description to me. I think parking mouth down was to ensure that if anyone was up in the bell chamber doing some maintenance they wouldn't nudge a bell and have it swing uncontrollably.
              You’re correct, the normal ‘parking’ position is mouth down BUT….
              in order to actually ring them, beforehand they are ‘rung up’ through half a rev and ‘parked’ mouth upright. From that point on, during the actual ringing they are swung through 360 degrees in one direction, then 360 degrees in the other. This can carry on continuously for anything from a few minutes on a practice night to over 4 hours for a full peal on heavy bells.
              This animation shows the action…
              https://washingtonringingsociety.org/galleries/animations
              #532647
              Nick Wheeler
                @nickwheeler
                Posted by Peter Cook 6 on 08/03/2021 12:42:47:
                That's definitely one reason. The bells in our church park mouth down so that the clock hammers can hit them when its chimes and strikes. There are wires to pull the hammers off the bells before rotating them to mouth up at the start of ringing.
                Lets not forget the idea of leaving a large weight resting against a 50×50 stick of ash. Or the even smaller peg screwed to the bottom of that stick if you're afflicted with Hastings stays.
                Ringing them down is the simple, common sense(that dreadful phrase again) way of preventing problems.
                #532654
                  Posted by not done it yet on 08/03/2021 19:46:14:
                  Doug
                  Or maybe they are very big, and almost incredibly well made: **LINK**
                  … a few glimpses of Timken's manufacturing ^^^
                  Hopper
                    @hopper
                    Posted by Grindstone Cowboy on 08/03/2021 14:20:19:
                    Many years ago, I was told – and shown – that the generators in the nuclear power station where I was working on the construction side were constantly rotated at a few RPM by electric motors when not in use. Now it all makes sense smiley
                    Rob
                    Those would probably have had white metal bearings if they are like the usual thermal power station generators. Barring gear motors usually keep the whole shebang slowly turning over to stop the steam turbine rotor shaft from sagging if its left in one position. 80 tons or more of large diameter wheels of blades all sat on a relatively small diameter shaft. Once they cool down to ambient temp they can be left stationary if necessary, as they often are for maintenance etc.
                    #532686
                    Hopper
                      @hopper
                      Posted by Michael Gilligan on 08/03/2021 21:05:24:
                      Doug
                      Interesting. Thanks for posting the link.
                      $20,000 bearings six-foot in diameter. Three weeks to heat treat (reduced now to one day) etc. There's a bit more to it than your average car wheel bearings!
                      I hadnt realised those gennies were so big when you see them up close. Different view from when you drive past them in the distance. Would be a nice job putting them up.
                      #532688
                      Grindstone Cowboy
                        @grindstonecowboy
                        Ah, now you mention it, I think they did mention shafts bending.
                        Rob
                        #532959
                        Douglas Johnston
                          @douglasjohnston98463
                          Posted by not done it yet on 08/03/2021 19:46:13:
                          Doug
                          Oh dear , I seem to have touched a raw nerve with my comment. It was just an idle thought I had while reading the thread. I rather like wind turbines, I have a couple of large ones close to my house and can spend ages just watching them.
                          Doug
                          Edited By Douglas Johnston on 10/03/2021 11:34:31
                          #532964
                          Hopper
                            @hopper
                            Yes I think they are rather beautiful to watch slowly turning away too. Then again, I always regarded thermal power station cooling towers to be works of art too.
                            #532976
                            Nigel McBurney 1
                              @nigelmcburney1
                              Hard drive bearings,disc spindle and actuator arm, in my day spindle bearing ball races had more than standard clearance and had preload via a spring,the lubricant and the quantity was to a special spec as a min 5 yr life was specified,I would not bother to re use these bearings in another application. I have seen severe brinelling on motor cycle head races particularly on competition bikes, I had a new Greeves trials bike back in 1961,which one of the first bikes to have timpken taper roller, after a couple of years use I removed the forks to check the bearing condition and lubrication as there was no greasing nipple,the bearing outer race surface had bright spaces,separated by black line of corrosion as the steering lock limits the travel of the rollers,very slight wear could be detected on the bright areas,in those days Timkens were expensive,so the old bearing continued in use and still being an apprentice with limited funds,replacement of chains and wheel bearings was deemed more important,after the overhaul when riding the bike on the road there was a very slight shimmy felt through the handlebars. Back then a lot of trials competitors rode their bike in competions at the weekend and it used it for road use during the week, summer holidays would be spent giving the bike an annual overhaul,,One thing I read about recently was that some road racers still prefer the cycle cup and ball bearing assembly compared to taper bearings as they reckon the bikes steer better.
                              #533120
                              Hopper
                                @hopper
                                Posted by Nigel McBurney 1 on 10/03/2021 12:29:27:
                                Could be less friction perhaps. Point contact rather than line. Longevity would be the roller's main advantage so not an issue in racing where regular replacement could be done.
