Backhead painting.
Backhead painting.
Home › Forums › Beginners questions › Backhead painting.
  • #850198
    Thomas Clarke
      @thomasclarke78224
      Before I put the boiler back on my locomotive I have the opportunity of painting the backhead with heat proof spray paint that I used on the chimney. I assume backheads on the full size engines were painted black for purley cosmetic reasons. Are there any disadvantages or advantages of painting the backhead onu 5in gauge locomotive? Any thoughts on this would be much appreciated. Thanks.
      Thomas
      #850227
      duncan webster 1
        @duncanwebster1
        Backhead on British locos were often covered with cladding, made working conditions a bit better.
        Can’t think of any advantage in painting a model backhead apart from aesthetics
        #850345
        Nigel Graham 2
          @nigelgraham2
          There isn’t an engineering advantage in painting the backhead on a miniature, unless perhaps it is steel, but it would look better painted with heat-resisting black paint.
          If clad, that would be painted instead.
          #850352
          Martin Johnson 1
            @martinjohnson1
            Full size locos were often un clad and unpainted, but soot, oil and muck cooked gently on a hot backhead makes a good substitute for matt black paint.
            Martin
