I have zero experience with this so I was hoping for some insight if you have a moment!
I am a hobbyist bladesmith and bought a touchmark last year to put my "stamp of approval" on anything I made for friends. (My actual work is a photographer, so not putting my name on stuff I've slaved over felt unnatural).
The touchmark is a 25mm square bar of O1 (hardened), with simple initials on it. It's perhaps a bit on the large size for a touchmark but doesn't look out of place.
The trouble for me is consistency. I am whacking it with a 1.5KG hammer when red hot and I have got good results, but also not so good results. I've done a lot of testing and It's just real tough to get even pressure and a good imprint with this. For the one project I've used it on for my friend, the end result was perfect but there is a lot of hit and miss…
I'm wondering if I could introduce some sort of arbor press to help even out the pressure and make it repeatable (and a hell of a lot easier!). Holding it all whilst the steel is red hot and giving it a whack isn't too easy for me…
Would something like this work? https://www.axminster.co.uk/axminster-ap1-arbor-press-340042
I have no idea what sort of force is required for this to work, hence why I'm asking! Spending as little as possible would be ideal, as I don't really have much use for press otherwise.
I should add, it really does need to be a good, deep stamp because after this operation I need to go back and straighten, and do the heat treatment process, all of which usually involves scaling to some degree. (So if it's too light, it can almost come off just through the scale!)
Edited By Richard Harris 5 on 23/03/2018 15:43:04
