Posted by sean logie on 25/09/2017 07:48:46:
when the hitch started squeaking, thought it was the car at first ,then I stopped and bounced up and down on the drawbar ,it was definitely the hitch that the noise was coming from
Sean
Not convinced Sean, bouncing up and down on the bar and squeaking might also mean the tow bar bolts are working a bit.
Most stability issues these days are caused by poor loading, you see vans with 4 pushbikes loaded in them, twin axle vans with the nose in the air because the hitch is set too high, and so much for a legal nose weight.
I guarantee if you come across a van towed at 40 wagging it's backside it's due to the owner (the one with the white knuckles on the wheel) with all the weight of his awning behind the axle.
As to speed of the lorry you follow at 58 or so isn't breaking the law to do you a favour. He's using his Tacho and doing 50 which is accurate, just check your sat nav. However the bloke in his Toyota who thinks he's good and right on the 50 limit is in fact doing 43 so I'm not surprised caravan towers get a bad name and truckers don't
