Another silver solder question
Home › Forums › Beginners questions › Another silver solder question
Viewing 15 posts - 1 through 15 (of 15 total)
  • #126512
    Bill Dawes
      @billdawes
      Hi all, as part of my deliberations on the building of Emma Victoria, (I have started, all the 'easy bits' so far) I am reviewing silver soldering practices in readiness for the day I get to the boiler. After my traumas with a GLR vertical boiler I look forward to this with some trepidation I have to admit as I am sure a loco boiler is several steps up from a simple verical boiler although hopefully I have learnt a thing or two now.
      My question is, looking back through many issues of ME I have come across reference to people hot rodding, these people seem to be experienced model engineers, however on the Cup Alloys website for instance they advise that hot rodding is not a good idea.
      Another issue I struggle with is one of direct heat, avoid direct heat is often quoted yet I have seen in several photos and UTube videos the flame being applied directly to the joint.
      Any guidance will be appreciated from you silver solder gurus.
      Bill D.
      #6821
      Bill Dawes
        @billdawes
        #126513
        Matts BitsNBobs
          @mattsbitsnbobs
          Can't advise you in this instance but all I can say is what ever cup alloys advise i would take as gospel. They have given me loads of advise over the last few years and all of it has been brilliant, so give them a call and do as they say! Good luck Matt.
          #126515
          Nigel Bennett
            @nigelbennett69913
            Bill
            I think the "avoid direct heat" is probably more to do with oxy-acetylene or oxy-propane, where the flame is particularly hot and fierce. It can easily over-cook the flux or melt the metal locally! With a straight propane torch, you can't really avoid "direct heat"! I've built a few copper boilers in my time using only propane, and the sensible advice is to use the correct flux for the grade of solder you're using, heat things up quickly (so the flux doesn't go off), and make sure the surfaces are clean and well-fitting (with 0,1mm/0.004" clearances or so) before you start.
            It would probably be a good idea to get somebody experienced to be with you when you start cooking up the boiler seriously – even if he (or she!) merely nods their head quietly in the background. If you're in a club, a likely choice is one of the boiler inspectors.
            #126531
            Keith Hale
              @keithhale68713
              Hi Bill,
              Use "hot rodding" as a means of adding extra flux to a joint already fluxed.
              Home made flux coated rods are not recommended for the model engineer because
              • the amount of flux is limited,
              • the flux is not as active as a "factory made fluxed rod, and
              • it invariably pushes the engineer to using a heating technique more akin to welding.
              • Result lack of penetration onto the joint.
              Heat the joint and let the silver solder get its heat from the joint – not the torch.
              Use the thinnest rod practicable
              More advice on http://www.cupalloys.co.uk/best_practise/
              Keith
              PS Thanks Matt for your comments
              #126543
              nigel jones 5
                @nigeljones5
                Indeed, beware a very hot flame – and in particular the blast pressure of the oxy flame. I avoid direct heat wherever possible but its not normally a problem with propane. Flux choice also becomes critical with heat type and boiler size.
                #126557
                paul rayner
                  @paulrayner36054
                  Hi Keith
                  thankyou for the link
                  it has made very intresting reading now added to my favorites
                  paul
                  Posted by CuP Alloys 1 on 09/08/2013 15:04:57:
                  Hi Bill,
                  Keith
                  #126596
                  Bill Dawes
                    @billdawes
                    Thanks guys and particularly Keith who helped me in the past with my GLR boiler. I understand better now the distinction between hot rodding as an addition to normal joint fluxing rather than trying to using it as the only means of fluxing.
                    Had another read of the Cup alloys guidance which is excellent.
                    I think I will have a few practice runs on different joints to try to brush up my technique, within the realms of affordability of the silver solder of course. Problem is that I have found that a small joint with very little mass of metal is easy to heat up and get a successful joint, very diifferent to heating up a whole boiler., would another gas cylinder and torch benefit in this respect?
                    Incidentally has solder come down in price, read the other day that silver prices have dropped sharply, maybe a good time to stock up a bit.
                    Bill D
                    #126696
                    Ian S C
                      @iansc
                      Two torches do help greatly, a mate to hold one of them helps even more, I know, I'v tried doing it on my own, interesting to say the least. Ian S C
                      #126779
                      shaun meakin 1
                        @shaunmeakin1
                        Hi BIll,
                        you are correct the price of silver has dropped recently and this is reflected in our prices on the web.
                        #126970
                        Bill Dawes
                          @billdawes
                          Thanks for advice guys, one final (for the moment) question, I am never sure what size of rod to use, is there a 'formula' or rule of thumb for this. I assume it depends on type of joint / mass of metal etc.
                          Bill D.
                          #126980
                          MICHAEL WILLIAMS
                            @michaelwilliams41215
                            Hi Bill ,
                            Thre is no specific rule about rod size to use . As you say yourself it depends on size of job or I suppose more accurately the size of the actual joint being made . One thing to consider though is the rate at which rods get shorter as you have to feed them in – too small a rod and they just disappear in seconds on boiler work .
                            A few general notes :
                            You might like to consider using pre-placed silver solder for some jobs . When doing doing steel assemblies I often jig the parts together , pre flux and pre apply solder and then just heat as rapidly as possible . A developed version of this procedure is used extensively in the aerospace industry using closed kilns / furnaces . Sometimes air atmosphere but more commonly vacuum or inert gas atmosphere . Special brazing materials are made for this work – sometimes supplied in fine granular form rather than rod .
                            Anyone getting propane heating equipment anew might like to get forced air supply type torches rather than self blowing type . They are a bit expensive but not too difficult to make yourself .
                            Gas torches usually have two flame zones – an inner hot cone and a more diffuse and larger outer cone . A less well defined zone in the flame has a reducing characteristic – it will remove oxides off (especially) copper work pieces . You can use this property deliberately during long heats to avoid too much oxidation and sometimes to clean up an area of work which is a bit dirty . There is a theoretical region where the flame should be reducing but better to find it yourself experimentally – hot copper shows as bright clean metal in the flame when you've got it right .
                            There's lots more .
                            Regards ,
                            MikeW
                            #126993
                            Bill Dawes
                              @billdawes
                              Thanks for that Mike. To be more specific then, if you were making a boiler such as that found on a 5" gauge loco like Emma Victoria. what size rods would you use, ie what size for say the tubes and would that be different for the shell etc. I appreciate there is a lot of experience gained from trial and error, I would just like to benefit from other peoples trial & error as much as possible!!!
                              Hopefully when the series on Emma reaches the boiler construction it will have the same excellent level of detail that Henry has given so far.
                              Bill D.
                              #127015
                              Sub Mandrel
                                @submandrel
                                I don't know if others find this, but with my propane torch I find that, even if the tip of the cone is the hottest bit, the most heat goes into big jobs if the tip of the cone is 1/2" – 1" away from the job. I wonder if too close interferes with full combustion of the gas.
                                nigel jones 5
                                  @nigeljones5
                                  rods – 1.5mm max for a 5" with propane.
