Aluminium Rod
Aluminium Rod
Home Forums General Questions Aluminium Rod
  • #23410
    Oompa Lumpa
      @oompalumpa34302
      #157931
      Oompa Lumpa
        @oompalumpa34302
        I couldn't quite find a Topic section with "I Forgot" as the title.
        I remember buying these years ago and I know they are for "Welding" but for the life of me I cannot remember the process. Was this the (is this?) the stuff sold by Machine Mart for Aluminium welding where you use a Stainless Brush to clean the area to be welded?
        The rods themselves are around 14" long and a quarter inch diameter.
        Sorry guys but I am starting to suffer amnesia I think!
        graham.
        Edited By Oompa Lumpa on 15/07/2014 20:28:31
        #157950
        Bazyle
          @bazyle
          I have some aluminium solder wire but less than 1/8 dia. Your 1/4 seems a hefty size even for welding filler.
          #157951
          Bazyle
            @bazyle
            duplicate post
            Edited By Bazyle on 15/07/2014 22:05:52
            #157974
            HomeUse
              @homeuse
              Had some similar but 1inchx1/4inch rod – marked PURE-D – used by electrical engineers to “solder” underground cable joints. A case was clipped over the spliced wire joint and molten aluminium was poured in.
              Think the stamp means that it is “pure”
              Hope this helps
              #157978
              Oompa Lumpa
                @oompalumpa34302
                Ah Ha! I remember now. This was liberated from a job being conducted by that company beginning in B and ending in T. 'Twas a job in Newcastle and indeed, it is for melting into joint couplings. The rods are marked PURE-D as you can see in the photo.
                Thank you for jogging my memory.
                graham.
