Yes, Geoff, that is the one.
A friend picked up this machine and I was looking for some specs – motor power, spindle fitting, can it be be used with a stub arbor, belt pulley arrangement, etc.
I think his jack shaft has only one pulley at present and a separate motor has been fitted with a belt from motor tp spindle pulley. Says lowest speed is 160rpm, which is rediculous as it looks as though quite large cutters can be fitted.
I daresay he will get it apart somehow, but he knows little more about it at present than it is heavy! I’m guessing it will be a 1” arbor?
