I have several digital calipers, three cheap Chinese 150mm/6" size and my old 150mm/6" Mitutoyo and the heavyweight 300mm/12" Mitutoyos. I can trust the Mits to measure exactly, inside or out, but not the cheapies, especially not inside.
A set of tee shaped rocker gauges is worth getting, and getting to know well. For bores, if you don't have the means to measure inside accurately, the safe way is to make a plug gauge. Say, if your bore was to be 50mm, then a double ended plug gauge with one end 50mm and the other 49.95mm would work quite well. When the small end fits, you are close and the full size should not quite go in. Size for size will not fit without force.
It is worth gradually building up a few good make second hand micrometers, they are usually easy to judge from their cosmetic condition whether they have been abused.
