Adjusting the gibs on a wm18
Home › Forums › Beginners questions › Adjusting the gibs on a wm18
  • #161987
    Brian Abbott
      @brianabbott67793
      Hello All..
      could anyone offer me any advice on adjusting the gib strips on my Wm18
      thanks in advance.
      #7285
      Brian Abbott
        @brianabbott67793
        #162005
        Yngvar F
          @yngvarf
          Hi
          What do you need to know?
          They are tapered gibs held between two adjustment screws.
          Be aware that the threaded part is quite small compared too the head, so don't use too much force.
          If the gib is stuck try loosening the screw in the big end and move the table in that direction.
          Yngvar
          #162070
          Brian Abbott
            @brianabbott67793
            Thanks for the reply,
            just unsure how to adjust, would I best to remove and clean then refit and adjust.
            otherwise I guess you wind the gib strip along until no play in the table can be felt.
            The other reason I wanted to tighten things up is that the winding handle feels very loose, so much so that in certain positions the handle will drop moving the table slightly, not sure if I can adjust the leadscrew nut just to tighten things a little, all part of the charm of these machines maybe..
            anyhow thanks again.
            #162095
            Yngvar F
              @yngvarf
              Hi
              I took mine apart to clean out the shipping grease but there wasn't much of it IIRC.
              There are thrust bearings on the lead screws. Tightening the nut on the hand wheel a little will stop it turning on it's own.
              If you put some drag on the gibs with the table locks you can test the feel of a tighter gib.
              Yngvar
              #162227
              Brian Abbott
                @brianabbott67793
                Thanks for the advice Yngvar..
                Will give it a go when I get chance..
