Adjusting DRO scale
Adjusting DRO scale
Home › Forums › Beginners questions › Adjusting DRO scale
  • #430557
    Sean Cullen
      @seancullen60833
      Having been given a set of DROs for my milling machine I find 2 are slightly too long. I didn't fancy having them overhanging, is it ok to cut them down to the correct length? They are the ones with remote readout from Arc.
      Sean
      #9873
      Sean Cullen
        @seancullen60833
        #430560
        Brian G
          @briang
          If you mean these, (Link) no problem at all. I wrapped the bar in masking tape first to stop the tape ripping then used a fine hacksaw.
          BTW, if you ever want to go down that route, they work fine with TouchDRO.
          EDIT:  Should have mentioned that unless you remove the read head there is no need to clean up the end, it is encased in the mounting bracket.
          Edited By Brian G on 26/09/2019 15:31:11
          #430570
          Sean Cullen
            @seancullen60833
            Many thanks Brian, that's the beast. I even bought a new hacksaw today so now I have something to test it on 😊
            Sean
