Adding a leadscrew to a lathe ?
Home › Forums › Workshop Tools and Tooling › Adding a leadscrew to a lathe ?
  • #20689
    Rich2502
      @rich2502
      #597585
      Rich2502
        @rich2502
        Any one retro fitted a leadscrew to a small lathe? ( 15-20" between centres )
        There are now motor controlled set ups withh off the shelf ballscrews that require no gear train so that would cut out a lot of the work.
        Is this a practical project or a rabbit hole ?
        #597586
        Clive Foster
          @clivefoster55965
          In principle pretty practical but, as you will only do it once, bound to be 5 times the work and general futzing about than you expected.
          Lots of careful measuring beforehand will be essential. This is the sort of job that really makes you wish for decent 3D CAD skills.
          #597589
          John P
            @johnp77052
            Posted by Rich2502 09/05/2022 14:15:41
            Warco cnc conversion Mew 207 through to 212,
            a bit bigger than your machine but the principle much the same.
            Martin Connelly
              @martinconnelly55370
              Are you starting off with a lathe with no leadscrew? Often people with electronic leadscrews just add a stepper drive to an existing leadscrew. This allows the half nuts to be engaged and disengaged as required. Adding a ballscrew and nut would require a different way of working as there are no half nuts that work with ballscrews. You may have to come up with a way to disengage the carriage drive and move the ball nut away from the carriage if you wanted to do something that required moving the carriage manually. Back driving the ballscrew may not work.
              A permanently fitted ballscrew drive is halfway to having a CNC lathe, is this your aim?
              Martin C
              #597597
                If it is a small watchmakers type lathe with a clamp on saddle and no existing leadscrew then the saddle will probably not be designed to slide up and down the bed like on a larger lathe so you may get problems with twist and racking of the carriage.
                #597599
                Frances IoM
                  @francesiom58905
                  The Taig/Peatol small lathe has no leadscrew – there is, or was, a commercial addon package tho my lathe came with a jury rigged leadscrew using a threaded rod and a nut formed by bit of thin plate, the original rack + gear having been removed – I re-installed the rack as it felt more comfortable but if it were my only lathe think I would look towards a leadscrew of some form.
                  #597607
                  bernard towers
                    @bernardtowers37738
                    Look at deansphotgrafia site this shows Taig leadscrew fitting.
                    #597621
                    Peter Cook 6
                      @petercook6
                      There is an example of a leadscrew setup I fitted to a Taig here.
                      Taig Lathe V3 | Model Engineer (model-engineer.co.uk)
                      #597622
                      Steviegtr
                        @steviegtr
                        Have a look at Ades workshop on Youtube . He is doing one now. Along with a lot of other upgrades.
                        Steve.
