Acme or not?
Acme or not?
Home › Forums › General Questions › Acme or not?
  • #595928
    Stephen Follows
      @stephenfollows82099
      I’m restoring an old vice. The screw looks like an Acme in all respects. Problem is I can’t find it in tables. It’s 7tpi x 0.54 inch diameter.
      Tables go from 6 tpi to 8 tpi, no 7.
      I need to make a new spindle and have no idea what change gears to use on the lathe. Anyone come across this thread before? It’s Swiss made BTW.
      #28683
      Stephen Follows
        Odd thhread
        #595939
        not done it yet
          @notdoneityet
          Are you sure it is not metric? Swiss made, so likely?
          #595940
            Diameter falls within TR14 max/min but pitch is between the usual 3 or 4 mm
            #595942
            DC31k
              @dc31k
              If it is Swiss, is there a possiblity it could be metric, trapezoidal form? The dimensions are not so far off 14 x 3.5mm pitch.
              How are you measuring the pitch? If you measure over 21 threads, do you get exactly 3 inches?
              You would have to tell us what lathe it is in order for us to advise on gears.
              #595950
              not done it yet
                @notdoneityet
                Posted by JasonB on 26/04/2022 19:02:53:
                Yes, 3.5mm near as dammit isto swearing.🙂
                #595962
                  Rumour [or at least a discussion on hobby-machinist] has it that the Kurt D60 screw is 7tpi stub ACME
                  https://www.hobby-machinist.com/threads/harden-kurt-vise-screw-threads.24385/
