Reply To: Weller soldering iron bits
Home Forums General Questions Weller soldering iron bits Reply To: Weller soldering iron bits
#623953
Robert Atkinson 2
    @robertatkinson2
    No, that is NOT a Weller W60P. In fact I don't think it is a rebadged Weller at all as it is not magnastat.
    The RS part numbers for Andrews iron are:
    Handle 544-594
    Element 315 deg C 544-601
    Element 370 deg C 544-617
    Element 430 deg C 544-623
    Screwdriver bits
    0.8mm 544-588
    1.6mm 545-216
    2.4mm 544-586
    3.2mm 544-550
    Needle bit 1.2mm 544-572.
    These are long discontinued. I got the data from a 1986 catalog. You could try a search on ebay for the RS part numbers. You can do a saved search and get a notification if one is listed.. The closest bit I can find is the Weller CT5 series for the W61 iron. e.g CT5 C6 3.2 mm Screwdriver Soldering Iron Tip RS stock no 176-6879. This will probably need modification to fit though.
    Robert G8RPI.
