Comfortable Working Height for a ML7
Home › Forums › Beginners questions › Comfortable Working Height for a ML7
  • #375275
    Guy Lamb
      @guylamb68056
      In L H Spareys's book 'The Amateurs Lathe' he suggests a convenient working height of a lathe to be the height from the floor to cross slide to equal that of the operators bent elbow to the floor. Now I've got arthritis of the lower back and I think at this height I will have to stoop a little to operate my machine meaning discomfort for any length of time, does anyone else have a thought on comfortable working heights?
      Best
      Guy
      #9368
      Guy Lamb
        @guylamb68056
        #375283
        Mike Poole
          @mikepoole82104
          A bar stool may let you sit and operate the lathe especially if you are just watching a long traverse. If you have it on a Myford stand it can be blocked up to raise the whole stand to prevent stooping. If you are making a stand you could start with it a bit high and cut it down or use a duckboard to work off.
          #375289
          Mark Rand
            @markrand96270
            I haven't yet got arthritis, although it runs in the family. But I've found with everything in the shed that having the main operations at about elbow height is the most comfortable. For those of us that are no longer in the first flush of youth, it can be worth getting spectacles that are optimised for a 'straight back' working distance at this height.
            #375307
              I think measuring is the most important bit for stooping and making a bad back worse. But power feeds certainly help, especially if there is a trip-out system that works.
              Mike’s ideas of raising either the lathe stand or the operator are good. Shortening legs is more difficult unless they are easily adjusted/levelled. Leaning against a stool is more apprpriate than actually sitting – one cannot move as quickly from a sitting position if something goes awry.
              One should never allow students to sit in front of chemistry experiments, for instance – well, I never did, for one. Clear access – or escape – required at all times, and no trip hazards!
              #375330
              Andrew Tinsley
                @andrewtinsley63637
                I have an ML7 on a Myford stand and never thought about height. I have just finished refurbishing a 9×20 lathe for a disabled friend, It is approx. one foot higher than the Myford and it is a joy to use, no bending or straining. It is much higher than most lathes and I am 5 foot ten inches high. Made me think!
                Andrew.
                P.S. I now have to reduce its height considerably for use by my friend.
                #375341
                Mike Crossfield
                  @mikecrossfield92481
                  I’m 6’1” tall, and raised my Super 7 cabinet by 4 inches to stop backache. A bit more would have been even better, but I happened to have a length of 4 inch square hardwood to hand.
                  #375364
                  SteveW
                    @stevew54046
                    Make it too high rather than too low. You can always stand on a box or a pallet duckboard to see right over the top if you want or need to.
                    #375373
                    ega
                      @ega
                      Another way of gaining extra height is to wear clogs with thick soles and heels; they are said to be good for standing on hard floors too.
                      #375418
                      Guy Lamb
                        @guylamb68056
                        Thanks Model Engineers, bench top height of >36" seems to feel right minus a 1" rubber type mat. Also a bum perch will take the ache out of prolonged standing (which seems to be far worse than moving about). As for clogs, I used to ware them, ideal for hot work as they wont burn through the sole if hot work stood on, definitely a knack in getting used to walking in them. They soles were shod with steel 'caulkins' and your approach could be heard before your appearance by a couple of minutes, but very comfortable though.
                        Best
                        Guy
                        #375428
                        duncan webster 1
                          @duncanwebster1
                          If you want some clogs there is a chap in Stockport still making them. Most comfortable footwear you'll ever find partly because they are made to fit you exactly, not some compromise. I find most shop bought shoes too narrow, onlt Clarke's do width fittings nowadays.
                          Edited By duncan webster on 11/10/2018 09:22:12
                          #375449
                          ega
                            @ega
                            Duncan Webster:
                            Could you share the Stockport clog maker's details?
                            I used to drive in mine but I would not do so today; then again, some like to drive in bare feet.
                            #375479
                            duncan webster 1
                              @duncanwebster1
                              Clog maker link
                              He mainly makes them for Morris/Clog dancers, needs to be kept in business so that I can get mine fettled. No problem driving in mine, but I tend not to.
                              Edited By duncan webster on 11/10/2018 14:23:50
                              #375480
                              ega
                                @ega
                                duncan webster:
                                Thank you. I love those co-respondent clogs!
