Boiler end plates
Boiler end plates
Home › Forums › Beginners questions › Boiler end plates
  • #345214
    Joe King
      @joeking68307
      Do boiler end plates need to be flanged please ?
      #9124
      Joe King
        @joeking68307
        Boiler end plates.
        #345242
          A lot will depend on the size of boiler, material and method of jointing so hard to say without more details.
          J
          #345248
          Joe King
            @joeking68307
            Say 16swg copper tube between 50mm to 100mm diameter as in the simple low pressure model steam engines.
            I had copper discs for the ends in mind say 3mm thick and silver soldered.
            Hope this clarifies a bit ,
            #345268
              A 16 to 14 gauge disc, flanged and slightly domed with a robust centre tube or stay would be normal at 100mm.
              michael howarth 1
                @michaelhowarth1
                Published designs of most Gauge 1 boilers with 60psi working pressure and boiler diameter 50mm + are usually copper discs let into the boiler tube and silver soldered or just simply butted up against the boiler tube and silver soldered. I usually use 2.5 – 3mm thickness.
                Mick
                #345300
                Joe King
                  @joeking68307
                  Thank you
