Myford ML7 Manual Instructions
Home Forums Beginners questions Myford ML7 Manual Instructions
  • #344902
    Andrew Moore 6
      @andrewmoore6
      Please can somebody explain what the circled numbers refer to (numbers 1 to 8, excluding 6!). Thanks
      #9119
      Andrew Moore 6
        @andrewmoore6
        Fig 36 Page 26
        #344906
          Good question, Andrew
          They seem to have shuffled the numbering that was allocated on page 25 dont know
          Rick Kirkland 1
            @rickkirkland1
            Andrew, the photo, fig 35 on page 25 has no connection with the 3 diagrams in fig 36, page 26 other than to indicate what each part is according to the numbers in brackets below the photo fig 35 at the bottom of page 25.
            The first diagram 1. on fig 36, page 26 is a simple gear train and should be read in connection with the screw cutting set up charts, figs 37 and 38 on page 27.
            basically 1 in fig 36 shows 2 as the driver, 7 as an idler, 1 is simply a spacer gear to fill the empty space on the stud and 4 is the driven or leadscrew gear. If you read the diagrams 2 and 3 in fig 36 in conjunction with the charts it's all pretty self explanatory. The numbers 1,2 and 3 in the diagram boxes refer to the end column marked "set up". The circled numbers show the relative gears and positions taken up on the studs to provide simple or compound reduction train set ups, hence the side views of the banjo indicating with dotted lines the gears 'behind' gears. You'll notice that certain trains require the leadscrew gear to be on the inboard or outboard end of the leadscrew depending on the train type requirements. Simply move the spacer from one side of the leadscrew gear to the other.
            #344928
              Posted by Rick Kirkland 1 on 07/03/2018 21:41:28:
              But it fails to do that.
              Robbo
                @robbo
                If you can access a Super 7 Manual and look at the corresponding pages, the diagrams are much more easily understood, as they do away with this numbering and refer directly to "1st Stud, 2nd Stud, Leadscrew, Driver" etc which directly relates to the tables.
                I would scan the page in, but we have recently been attacked by malevolent gremlins (probably the Russians) and the computer is gradually being put back to work, so no scanning just now. It is hugely frustrating!
                If you are in the Myford Yahoo Group there is an old S7 manual in the files section, probably in the last file, which is actually a folder with several files in it.
                #345041
                Andrew Moore 6
                  @andrewmoore6
                  Thanks everybody for your replies.Regards Andrew
