First go at anodising ali – cathode material?
Home › Forums › Beginners questions › First go at anodising ali – cathode material?
  • #330226
    Robin Graham
      @robingraham42208
      I've got a couple of solid cylindrical (in the 'spherical cow' sense) aluminium parts which I would like to black anodise. They are about 3" long by 1.5" diameter.
      There's a lot of stuff on t'internet about DIY anodising, The most popular cathode material seems to be lead, but there are also articles recommending stainless steel. I have several cheapo SS cooking pots which I use around the workshop for various purposes, so I'm wondering if I can use one of these to double as the anodising vessel and the cathode? Anyone tried this?
      Rob
      #8985
      Robin Graham
        @robingraham42208
        #330228
        Clive Hartland
          @clivehartland94829
          One anodising place I used had Tin cathodes and he used Titanium holders to support the jobs.
          #330355
          Jon
            @jon
            Havent done any anodising since 2006 not worth the effort in space taken up. Back then a closely guarded secret only 3 gave any knowledge and all told porkies. Quite different now theres dozens of write ups.
            Much prefer to get a pro job done by one of a few places nationally that care and know what theyre doing, theres a good 90% dont care often scrapping weeks of work.
            Current anodisers do work for JLR amongst others have lead lined baths and loads of steel based jigs with titanium spring clips. Just getting 6 weeks of work ready to drop in next Monday collect the following day approx 62 one off parts.
            Do have a mate thats just setup to do basic anodisng but can only do mop polished items and leave an 80% gloss finish. Takes a good anodiser to brighten evenly bead blasted parts to a satin to gloss finish, many scrap the parts or lose entirely.
            #330363
            V8Eng
              @v8eng
              There has been quite a lot of coverage on this forum before now, they might be worth a read through.
              If you put anodising into the search box above your first post (leave the all topics bit on) they will be listed.
              Hope this might help.
              Edited By V8Eng on 03/12/2017 18:37:49
              #330809
              Robin Graham
                @robingraham42208
                Thanks for your comments. I have had a look at the discussions on this site and elsewhere, but haven't found anything germane to my question about using a stainless steel tank as the cathode. Perhaps because it doesn't work! I'll suck it and see.
                Probably I should just farm the job out, but for sure I'm not the only one here who gets a kick out of doing stuff at home if possible.
                As an aside I looked in my acids cupboard and found the concentrated sulphuric, which was supplied in a plastic (polyethylene?) bottle had turned coal black – I shall dispose of that! With care obviously. Next lot will be in a glass Winchester bottle.
                Cheers, Rob
                Edited By Robin Graham on 06/12/2017 23:20:45
