Change gears
Change gears
Home › Forums › Beginners questions › Change gears
  • #323583
    kevin barron
      @kevinbarron12390
      I have hercus 260atm metric lathe set up to cut imperial would like to know metric change gear set iup it has gear box
      #8929
      kevin barron
        @kevinbarron12390
        Hercus 260atm metric lathe
        #323585
        John Ockleshaw 1
          @johnockleshaw1
          Hello Kevin, Here are the gears for metric pitches. They will suit you if your lead-screw is 8 TPI.
          Regards, John
          #323587
          John Ockleshaw 1
            @johnockleshaw1
            This may be more easily read Kevin
            #323806
            kevin barron
              @kevinbarron12390
              My leadscrew is metric 3mm but change gears set up to cut imperial need gears for metric with quick change gearbox
              #323810
              Jens Eirik Skogstad 1
                @jenseirikskogstad1
                Kevin,.. you can download the program for calculating the change gear if pitch of the lead screw and a set of change gear is known and the threading size is selected to create threads.
                Go to this link –> **LINK** and download the program –> NthreadsP
                and if your lathe has a screwcutting gearbox —> BoxfthreadP
                #323837
                  You might find some charts on one of the South Bend lathe sites, yahoo group or even the SB section on Home Shop Machinist forum. Pretty sure as Hercus copied SB to a tee the gearing would be the same.
                  Hercus are still in business and still reconditioning the 260s so they could probably tell you. And there is a very enthusiastic fellow selling parts for the older Herci who might be able to help too.Here **LINK**
                  #323854
                  Robbo
                    @robbo
                    Kevin
                    This chart for gearbox and changewheel lathes may help, as well as Jens links.
                    #323856
                    Yngvar F
                      @yngvarf
                      You need a 18t or 45t stud gear. A idler gear. usually 80t on South Bend clones. and a 60t screw gear.
