‘Grease nipples’ and oiling
Home › Forums › Beginners questions › ‘Grease nipples’ and oiling
  • #319593
    Roger Clark
      @rogerclark
      I'm restoring a Denham Junior mk2 lathe and I think it was the case of if it moves oil it!!!
      I dont have a problem with this regime but I seem to have an issue with doing it. The oiling points look like grease nipples and there's no way my oil cans will fit so am I missing something here or is there a cunning plan that I don't know of?
      Cheers
      Roger
      #8892
      Roger Clark
        @rogerclark
        #319594
        David Standing 1
          @davidstanding1
          You need one of these:
          Edited By David Standing 1 on 01/10/2017 22:02:47
          #319597
          David Standing 1
            @davidstanding1
            Or, if you are feeling flush, one of these:
            Ian Skeldon 2
              @ianskeldon2
              Or if you want to hang onto your hard earned, one of these…**LINK**
              #319606
              David Standing 1
                @davidstanding1
                Posted by Ian Skeldon 2 on 01/10/2017 22:08:40:
                Ooh, might have to get one of those myself! Ta wink 2
                #319612
                charadam
                  @charadam
                  #319613
                  Mark Rand
                    @markrand96270
                    I have three of the Wanner oil guns, each of which is used with a different oil or fitting. They are far superior to the Tecalemit oil guns that were suppied with Myford lathes, which is a shame, since Tecalemit have been in business for many years.
                    #319622
                    Alan Johnson 7
                      @alanjohnson7
                      See Barry Forrest's design in MEW July 2011, Issue 178, Page 48 "An Oiler for the Myford Lathe." I made one, and it works very well.
                      #319638
                      Harry Wilkes
                        @harrywilkes58467
                        Posted by David Standing 1 on 01/10/2017 21:58:37:
                        I purchased one of the above and although it worked it leaked like a sieve crying when not in use I need to stand it in a container !
                        H
                        #319662
                        JohnF
                          @johnf59703
                          Posted by David Standing 1 on 01/10/2017 22:34:09:
                          Yep these are the business — I bought a mega expensive one from original Myford and it lubricates me more than the machine — since then a Press parts one and its a revelation no contest in my book !
                          #319666
                          David Standing 1
                            @davidstanding1
                            Ian/John
                            I have just ordered a Press Parts one – thanks!
                            #319694
                            Roger Clark
                              @rogerclark
                              And I've just ordered a Press Parts one too, thanks to all who replied
                              Roger
                              #319724
                              Phil Whitley
                                @philwhitley94135
                                NAAAAAAAH! yer all wrong, I got one of these http://shop.hle.co.uk/shop/grease-equipment/oil-equipment/oil-guns-9/side-lever-oil-gun.html From Nipple Shop, you also have to buy a flexy pipe and a nipple clamp (ooh er missus) from the aforesaid nipple shop, but what a tool (fnaar fnaar). I used it to clear all the grease from my Harrison mill, and what a difference it made, and the pressure, oh oh, I think I am going for a sit down!
                                Seriously, it does the job, and doesn't leak.
                                #319822
                                  If they used these, you could get away with a £4 oil can…
                                  #319913
                                  David Standing 1
                                    @davidstanding1
                                    My Press Parts oiler turned up today, precisely 24 hours after I ordered it online! Now that's what I call service.
                                    I was out this evening, so haven't had the chance to try it yet……..
                                    #320176
                                    martin107
                                      @martin107
                                      Posted by JohnF on 02/10/2017 11:08:38:
                                      Me to I used to buy parts for printing machines off them, I found the pump looking for a Heidelberg one as I used them many years ago.
                                      #320365
                                      thaiguzzi
                                        @thaiguzzi
                                        Posted by Neil Wyatt on 03/10/2017 09:40:50:
                                        Indeed.
                                        95%, nay probably 99% of machine tools use these ball oilers. Work perfectly, cheap, easy to replace.
                                        So, I read all these oil gun/Myford oiling problem threads and think what is the problem? Then I see a picture of a Myford oil fitting…..
                                        #320371
                                          I think the idea behind the Myford oil nipples and matching gun is that the oil is pumped in under pressure from the oil gun, thus flushing out swarf that has got under the carriage and between the ways. The normal ball type oil fittings don't do this. They just let a few drops from a normal oil can dribble through and mix with any trapped swarf to form a nice grinding paste.
                                          Whether Mfyord's flushing theory works or to what extent I have no idea. Their beds do seem to wear, but whether the correct oil gun was used religiously by previous owners over the past 40-60 years, nobody knows.
                                          #320374
                                          I.M. OUTAHERE
                                            @i-m-outahere
                                            I fitted my asian made mill with grease nipples as oiling points and modified an old grease gun to pump the oil in and it works perfectly .
                                            All i did was blank the end of the grease canister off so it creates an oil can and use the air bleed plug on the pump head to fill it , i have seen some modifications on the intrnet for the grease nipple coupling but never ended up doing it as the standard grease coupling works just fine with oil .
                                            Guy leutard was the inspiration for that modification .
                                            May be a problem with a myford as there is that oil point in the back pulleys and getting a grease coupling on and off could be a problem .
                                            #320377
                                            Douglas Johnston
                                              @douglasjohnston98463
                                              The use of a grease gun for oil works very well. I suffered for years with the old Myford oil gun which leaked oil everywhere and never sealed properly on the nipple. I just removed the plunger from the grease gun, sealed the hole in the end cap with JD Weld and put oil inside. You have to hold the barrel of the gun vertically so that the oil is gravity fed into the pumping chamber. You get that satisfying feeling of oil being forced into the nipples.
                                              Doug
                                              #320749
                                              Bizibilder
                                                @bizibilder
                                                Just received a Press Parts oiler – filled it with H32 oil and……………..oil in all the right places and no leaks. Brilliant bit of kit – Thank you!
