What are these stone sticks?
Home Forums Beginners questions What are these stone sticks?
  • #310744
    RichardN
      @richardn
      I picked up a tobacco tin of BA taps a few weeks ago at a boot sale, which aren't a full set but are in really decent nick- paid a quid but was then given several other tins of rusty taps, drills, and another tin with what look like marble but feel like chalk- some kind of stone sticks?
      I wondered if these were hard and could polish up the tip of a drill, or the flute of a tap, but they feel soft and chalky… about 5/16-1/2" in section if that helps?!
      Any thoughts?
      #8823
      RichardN
        @richardn
        Marble or chalk?
        #310748
        Mike Poole
          @mikepoole82104
          Have a look at Washita and Arkansas stones and see if they fit what you have.
          #310750
          John Baron
            @johnbaron31275
            Hi Richard,
            It is chalk ! Actually its called "French Chalk" and it is usually used for writing on steelwork, often powered and used when mending punctures in your bike tyres tube, to stop the glue sticking to the inside of the tyre.
            Edited By John Baron on 06/08/2017 21:14:46
            #310755
            Journeyman
              @journeyman
              Water of Ayr Stone, used by jewellers to polish after soldering.
              RichardN
                @richardn
                Well that's three apparently different answers for a start!
                But seriously, thanks, I'll start googling with at least some sensible words now- the suggestions above all seem very plausible from a 10 second Google on each!
                #310765
                  Just rub one on a bit of fine sandpaper or file If it produces fine white powder even more easily than blackboard chalk then it is French chalk. Given the quantity and inclusion with engineering tools rather than cyclists spanners I would guess a polishing stone is a distinct possibility.
                  #310766
                  Kenneth Deighton
                    @kennethdeighton43272
                    Hi RichardN, it is known as "French Chalk " and is usually used in the "heavy" ( Blacksmiths) engineering world to mark out work that does not need the precision that lathe and milling machines need , the end of the chalk is usually ground to a sharp point.
                    #310770
                    Nige
                      @nige81730
                      Water of Ayr stone. It looks like french chalk sticks but harder. I also have some in a tin. Used it long ago for removing very light blemishes from copper and aluminium.
                      #310774
                      Anonymous
                        French chalk can be rubbed onto files to stop pinning.
                        #310783
                        Vic
                          @vic
                          Another vote for French chalk. I have a pack of it I bought for marking hot metal.
                          #310785
                          Clive Hartland
                            @clivehartland94829
                            Looks to me like Soap stone, used to mark up steel plate etc.
                            #310789
                            jason udall
                              @jasonudall57142
                              Op has it…soft and chalky…defo soap stone or “french chalk”…
                              #310819
                              Brian Wood
                                @brianwood45127
                                An interesting side fact about soap stone [which is also my vote for these sticks] is that when it is heated and allowed to cool it is then hard, water resistant and resistant to wear. A useful property for fashioning low voltage electrical fittings, soft for easy working and durable when hard.
                                ​We used to use it for underwater light fittings to hold halogen bulbs around pipe cameras in submerged work.
                                Regards Brian
                                #310833
                                  Posted by Andrew Johnston on 06/08/2017 21:55:20:
                                  So can ordinary chalk. (English chalk??)
                                  #310846
                                  Georgineer
                                    @georgineer
                                    Looks like talc to me. I was brought up to call the solid talc, and the powdered form French Chalk. I think it's a magnesium compound, unlike ordinary chalk which is calcium carbonate. Blackboard chalk is actually calcium sulphate (gypsum, Plaster of Paris).
                                    George
                                    #310852
                                    Russ B
                                      @russb
                                      Posted by Georgineer on 07/08/2017 13:07:55:
                                      George
                                      I thought I was the only one………
                                      The guy changing tyres at the classic bike races looked at me like I was stupid when I mentioned grating talc on the tubes………. he said, "No… use french chalk" in a very worried tone….
                                      #310895
                                      Russell Eberhardt
                                        @russelleberhardt48058
                                        Definately talc, otherwise known as French chalk. It is mined near Luzenac 1800m up in the Pyrenees in southern France.
                                        I visited the talc mine there last year. It is one of the world's biggest talc mines and is an open cast mine on a massive scale. Well worth a visit if you are anywhere near. A video on Imerys Talc website shows the scale of the mining operation.
                                        Talc has a very wide range of uses apart from stopping files pinning when filing aluminium and using on baby's bottoms.
                                        Russell
                                        #311061
                                        mechman48
                                          @mechman48
                                          +1 for 'French Chalk', always keep a piece in my workshop coat pocket for rubbing on files when filing aluminium… & for rubbing on drill shanks when I can't read the impressed size.
                                          George.
                                          #311072
                                          nigel jones 5
                                            @nigeljones5
                                            This is the composition of common talc, Mg3Si4O10(OH)2, and this is for Crysotile asbestos, Mg3Si2O5(OH)4. Both are usually mined next to each other and despite reassurances to the contrary I wont have it anywhere near me.
                                            #311076
                                            Russell Eberhardt
                                              Posted by fizzy on 08/08/2017 20:37:54:
                                              Difficult to avoid Fizzy. It's an ingredient in lots of food and pharmaceutical products. It's in papers, paints, and plastics.
                                              Russell
                                              #311096
                                              nigel jones 5
                                                @nigeljones5
                                                totally agree Russell…but will I cover my beautiful four year old daughter in it…nope
                                                #313312
                                                  You might be interested to read this, in today's News, fizzy: **LINK**
                                                  http://www.bbc.co.uk/news/business-41003540
                                                  Russell Eberhardt
                                                    Interesting. Two things bother me about this sort of publicity:
                                                    1. All these big court cases have been in the U.S. and are typically tried by people who have no understanding of science.
                                                    2. There have been many studies to try to establish a link between talc and ovarian cancer. Some have concluded that there is no link. Some have concluded that there is statistically a slight increase in the risk which is already very low. Some have concluded that nothing is proven and more work needs to be done.
                                                    Now, if you are a researcher working on such a study who will become unemployed if the study is concluded you will , of course, want to suggest that more work needs to be done. This is a common problem with the way research grants are often awarded and scientists are employed on short term contracts.
                                                    Russell
                                                    #314487
                                                    Ada Cleen 2
                                                      @adacleen2
                                                      From the looks of it, if I'm not mistaken, it is probably French chalk; a chalk that is made from talc — the common use for such is to remove grease and mark fabrics or clothes, which is usually done by tailors.
